Question about Logitech LX 710 Keyboard/Mouse
Battery critical warning
Same problem as others have had. Battery critical warning even when the batteries have been changed. disconnecting everything and re-installing the software and putting in other batteries but still the same thing -the mouse works perfectly but it's just a tad annoying.
  • Alismum Feb 17, 2008
    Have cordless keyboard and mouse. Get low keyboard battery alert although I have changed batteries. Low battery icon on task bar continually flashing. Very annoying. Any suggestions?
  • rdctaylor Apr 24, 2009
    Keyboard says batteries are low and stops working. I have placed many sets of new batteries and the problem still happens. I've tested the new batteries in other devices and they are full.
    Novelist:
    Scholar:
  • 108 Answers
Check with the manufacture of the mouse (the website) to determine if they have a faq covering it. Your alternative is save the battery and get a different brand of mouse. I am assuming your mouse is wireless by the way. FYI....the problem rate of wireless devices to hard wired devices is probably in the order of 5000 to 1. I use a hard wired mouse and keyboard.
Posted on Jan 24, 2008
SOURCE:
No low battery warning..
  1. Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
  2. On the Select a power plan page, next to the plan you want to change, click Change plan settings.
  3. On the Change settings for the plan page, click Change advanced power settings.
  4. On the Advanced settings tab, expand Battery, expand Low battery level, Reserve battery level, and Critical battery level. Change the percentage of battery remaining that you want for each level, and then click OK.
Oct 14, 2013 | Acer Computers & Internet
My Acer Laptop battery shuts down completely at 40 - 30
Go to Power Options --> On the plan you are using select change plan settings --> Change advanced power settings --> Scroll down till you reach battery and click the + next to it to expand the settings --> Where it says Critical battery level and Critical battery action (on battery) make sure that the level is at 5% and the action is to hibernate. If it's set to do nothing, it will keep running until it's out of battery and completely shut off. Plugging the AC adapter would give it more power. If that isn't the problem, check your battery's connection and consider replacing the battery.
Nov 03, 2012 | Acer Aspire 5742G
I have a 2004 grand prix 3800 engine non turbo. Engine was eratic at cruise with rpms at 1200-2000. rpms would lope 2-300 rpms. I Changed air and fuel filter, and cleaned the throttle body. also checked...
i had a problem with all my lights coming on in my 2006 explore took it to dealer to find out that the battery was dying replaced it and they went away
Mar 26, 2011 | 2005 Pontiac Grand Prix
Changing a battery on a 2003 honda odyssey
no. removing the battery or disconnecting it will only reset any "service engine" lights or other warning lights that may be on.
Sep 14, 2009 | 2003 Honda Odyssey
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
LX5 mouse battery warning still flashing with new batteries
Hello
You need to reconnect the mouse.
Please read instructions from Logitech site
Best regards,
Zizzler
Apr 24, 2009 | Logitech 9311570403 Mouse
Battery drain
My wife's 2001 Jetta TDI had the same problem. First we changed the battery. (It was just about due anyway) No change. We then traced the power drain to the in-trunk mounted CD changer. This was an aftermarket CD changer but we went to the same source that the VW dealership uses. Of course one blames the other. The CD changer was even replaced with no change. If we are not using the car for long trips we unplug the CD changer and no more dead battery! Neither the VW dealer nor the AV installer could give us a good working solution to this problem.
Apr 06, 2009 | 2001 Volkswagen Jetta TDI
Ignition turns and key warning light comes on. Its a 98 Ford Expl
Sounds Like the Starter RELAY is Bad After Exhausting All other Test, Go For The RELAY
A SURE-SHOT way Is to Jumper Wire From Battery to (STARTER SIDE) of Relay if starter Works then Its the Starter Relay if NOT>>Then Its the STARTER<) Relay Instruction Below. STARTER Instructions Very Bottom
REMOVAL
WARNING: WHEN PERFORMING MAINTENANCE ON THE STARTING SYSTEM BE AWARE THAT HEAVY GAUGE LEADS ARE CONNECTED DIRECTLY TO THE BATTERY. MAKE SURE PROTECTIVE CAPS ARE IN PLACE.
  1. Disconnect the battery ground cable.
    1. Disconnect the starter motor solenoid relay switch wiring.
    1. Remove the protective cover.
    2. Disconnect the push-on electrical connector.
    3. Remove the nuts.
    4. Remove the cable.
      1. Remove the starter motor solenoid relay switch.
      1. Remove the engine sensor/generator wires.
      2. Remove the bolts and ground wire.
      3. Remove the starter motor solenoid relay switch.
      INSTALLATION
    5. Follow the removal procedure in reverse order NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
REMOVAL
WARNING: WHEN PERFORMING MAINTENANCE ON THE STARTING SYSTEM BE AWARE THAT HEAVY GAUGE LEADS ARE CONNECTED DIRECTLY TO THE BATTERY. MAKE SURE PROTECTIVE CAPS ARE IN PLACE WHEN MAINTENANCE IS COMPLETED.
  2. Raise and support the vehicle.
  3. Remove the starter motor solenoid terminal cover.
    1. Disconnect the starter wires.
    1. Remove the nuts.
    2. Disconnect the wires.Remove the nut and the starter ground cable
    3. Remove the bolt and the starter motor.
      1. Follow the removal procedure in reverse order. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Feb 08, 2009 | 1998 Ford Explorer
Battery not charging
In my opinion everything you done was right. I believe that the warranty is still valid and you should try to contact service partner. Maybe is the power charging electronic defective. Sorry but I don’t see any other possibility that you can do alone.
Sep 08, 2005 | Toshiba e800 Pocket PC
Logitech LX 710 Keyboard/Mouse Logo
286 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
