Yamaha Portable Keyboard Logo
Posted on May 01, 2009
Neeed to restore my Yamaha W7 to its original tuning
I loaned out my Yamaha W7. When I got it back, the tuning was shifted up by a fifth. How do I change it back to its original tuning?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
7129
Points
38
Http://www.yamahaforums.co.uk/modules.php?name=Forums&file=viewtopic&t=1554&start=0
Yamaha PSR-S750 61-Key Digital Workstation Keyboard is just showing a logo.
Question edited for clarity.
Try a Factory Reset. Try a power reset first. Disconnect from the mains plug for 15 minutes.
System Reset - Yamaha PSR-S750 Service Manual
ManualsLib https://www.manualslib.com > ... > Service manual
There are two reset methods in the SYSTEM RESET display: Factory Reset and Custom Reset. ... This function lets you restore the status of the instrument to the ...
2answers
How can I Import and export voices from or to Yamaha DGX 640 from my PC running with Windows 10 ?
ask yamaha this, direct to them or read the manual firsts. 2010 made.
lost the manual ? did you?????
any app you run most be from maker yamaha for w10.
Yamaha DGX-640 88-Key Portable Digital Grand Piano with Weight-Graded Hammer Action.all there is , is here
yam
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=640
https://usa.yamaha.com/files/download/other_assets/2/314552/dgx640_en_om_a0.pdf
i guess you talking about what page 15 states.
then page 97 how to do it>?
what it can do is all there song file wise.
it shows w7 max.
but some apps w7 sure can be loaded to w10 or drivers
using windows 10
w7 compatibility mode as MS tells you.
seen here.
windows 10 32bit or 64 I see this too
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=DGX
try these?
1helpful
Sir, have a Yamaha PSR 330, very recently the left speaker is not working. Do guide me for the same.
If it was playing fine and just stopped working while you were playing it, it's possible the speaker has failed, or a wire has come off. It is likely something you cannot fix yourself, and should find a local music store, like Guitar Center, who can repair it for you. It's generally not a very expensive repair at all.
If the sound stopped working from one side after you were playing with some controls or editing some voices, you may have set the panning all the way to the right, which would cause no sound to come out of the left speaker. In that case, you would simply need to set the panning to the center again while in editing mode.
If you are not too familiar with the editing features on the PRS 330, and not sure how to set the panning to the center again, you could always simply reset the unit to it's factory settings once again, while will return all the voices, effects, panning, etc. back to like the unit was when it was first taken out of the box and turned on. Here's the process to reset the Yamaha PRS 330 back to it's original settings -
Restoring the default (factory-programmed) settings While holding the C7 key (right-most key on the keyboard), press the power switch to turn the power on.
This operation erases backup data in this instrument (including backup settings in the Function mode) and
restores the factory default settings. The User Songs and the external Songs stored to internal memory will be
retained
None of that works and you do need to have someone look at the unit, here is a link to the Yamaha Authorized Service Locator to find the nearest authorized service center near you -
Servicer Locator
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
My ESP AX260 fell face down off the stand and the impact though not very acute broke the headstock and its completely off the body. The fretboard is intact but the Tune O Matic bridge fell off. I really...
I have reattached three headstocks myself as an amateur... I would take your pieces to a Luthier and see what he says about it. The ones I repaired, an acoustic bass required putting in a steel pin to stabilize the joint and some epoxy for the pin as well as the wood glue... an acoustic 6 string required only careful gluing, as did a 5 string banjo...
In all cases Titebond III glue was used for the wood and perfect mateup of the parts was required. Nitrocellulose laquer restored the finish using very fine emery sanding (4000 grit) wet sanding.
The perfect fitup and clamping is mandatory, and the gluing, if done right, will be stronger than the original wood. A key is to have clean LARGE areas of glue contact.
Please do take the unit to a professional Luthier... you should find them in your phone book...
I have a w7 keyboard ,given to me free,but with no owners' manaul,when I plug in amp there was no sound coming out I do not why?
There should be a headphone jack... try headphones first...
If no sound from the phones with the volume control up, the unit MAY have lost settings due to depleted memory battery.
Look on the web for "factory reset" procedure for the W7.
2answers
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
1helpful
Yamaha w7
I'm looking for parts for the Yamaha W7 keyboard.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
