Convergence hello my 3 colours seem ok but they seem to be not square whith each other then seem as if they need to be twisted so they all line up whith each other I can move the colours from left to right and up and down etc but cant twist them do you know how to fix this my model is a Pioneer SD-T5000
GO TO HELL
Posted on Oct 29, 2008
    Genius:
  • 1,153 Answers
Ok, well this is an indication that your convergence board is having some change since you can move all 3 and if all 3 are twisted then you can not narrow to one color, then I would suggest having amps changed. It's probably resistors also need changing. It will only get worse as you go on.
Posted on Oct 04, 2007
SOURCE:
Colors seperate and picture bent
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Oct 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
Samsung rear projection.Seems that the three colours are not aligned.There also has like a big line towards the top of the screen,which looks like a concave line.What can I do
problem with unit is convergence.you can eithor replace the board or repair it.all 3 ics should be changed-gotta also check 3.9 ohm resistors,
Sep 01, 2009 | Televison & Video
The colours on my set seem to be out of alignment,
you can try adjusting the convergence using the remote, if auto convergence and manual won't straighten the red out you will need the convergence ICs replaced
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 12, 2009 | Televison & Video
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem???
there is a way of lining the colours up in the service menu. to get into the service menu pres the "mute" button and then hold down the "mute" and "menu" button and the same time. this has to be done quickly. you then navigate to a screen which will have black square's on it. you will see the colurs that need to be lined up. it the colours wont line up. you will have to replace the convergience IC's. hope this helps you
Aug 05, 2008 | Televison & Video
Philips 50P8342
PTS 18008447871 can repair the board and give a price
Dec 13, 2007 | Philips 50P8341 50" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Service mode convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 29, 2007 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Ekse
