Question about Denon AVR-681 Receiver
On standby Denon AVR 681. The unit powers on, cycles and then shuts off -- goes into standby.
  • Anonymous Nov 13, 2007
    Mine does the same thing..........
    If anybody knows the problem ........please e-mail me.
    [email protected]
  • jeffels Mar 19, 2008
    I replaced the resistor with a composit 1ohm that I bought at Radio Shack it burned out right away. What should have I asked for at the store?
  • 3 Answers
[email protected]
Posted on Nov 13, 2007
Troubleshooting without a schematic. I found two 1 ohm resistors open in the positive 15 volt regulator circut. Located between associated power supply rectifiers and the 15 Volt Regulator. After checking for any short circuits I replaced the resistors. Ths restored operation of the unit. Owner thought the "Cable Guy" may have plugged something in wrong.
Posted on Dec 09, 2007
SOURCE:
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
Denon avr1403
disconnect all connections and cycle power once again if you have the same results the amp has an internal problem and will need to be repaired. If the amp stays on start reconnecting and cycle power after you connect each device
Jul 29, 2009 | Denon AVR-1403 Receiver
How to reset a denon AVR 681
Unplug the AVR 681, press and hold the "Speaker A" and "Speaker B" buttons. Plug in the unit then release both of the speaker buttons after a few moments.
Jan 02, 2009 | Denon AVR-681 Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Jan 13, 2008 | Denon AVR-681 Receiver
Powers on 5 sec then powers off
[email protected]
Nov 17, 2006 | Denon AVR-681 Receiver
Denon AVR-681 Receiver Logo
551 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
