Question about Samsung SGH-D600 Cellular Phone
Interesting problem I went to my friend,and we connected my d600 using usb cable to his computer.After 1 second my phone turned off.I turned on phone after 3-4 time,and on screen the time and date was different,my battery was charging althoug I didn't put him to charge.Since that day my d600 sometimes shuts down by himself,often I cant start him,even if battery is charged,but when I turn it on,date and time are different,showing that it's charging,working little slower.
    Scholar:
  • 113 Answers
Make sure the pins going to the usb port on it are all ok and they are not touching then, find someone with a similar D600 and relace your mem card and see if there is a difference, then try the battery and also note any difference. if its the battery, wich is likely, get it replaced, however there are cases of ic damage from faulty usb's, so if a working battery or mem/flash card dont work, send it to a repair man, after backing up all your personal stuff onto computer via BLUETOOTH. good luck!
Posted on Oct 09, 2007
SOURCE:
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
Rethink possible loop when I power up
Try this:
•Connect the phone to your computer with a USB cable that came in the sales package with your Lumia phone. If the battery has not been used for a long time, to begin charging, you may need to connect the cable, then disconnect and reconnect it.
•Press and hold the Power button for 10 seconds, and then press to turn on your phone again.
•Your PC should detect your phone when it is connected using a USB cable, if this is not happening you can manually switch the phone into specific mode following these steps:
1. Disconnect your phone from the USB cable.
2. Hold down the camera button.
3. Continue holding down the camera button and connect the USB cable between your phone and PC.
4. Continue holding down the camera button until you see the connect-to-computer screen on your Lumia phone display.
5. Release the camera button.
6. The Zune software on the PC should automatically detect your phone now and charging indicator appears on the display.
If the tricks above does not help, you will need to contact your local Nokia Care. You can find details by clicking the Contact us link in the support pages of the Nokia website for your country.
Note: Your battery has been partially charged at the factory but when taking your new device into use, please keep the charger connected for 30 minutes. It is recommended to use original charger (AC-16).
Aug 10, 2013 | Android Zte-z990
USB not recognizing my mobile phone
Try the following:
1 Connect the USB cable to a different USB connector on your PC. 2. Connect your phone to he PC with a different cable (these cables are fairly fragile). 3. Try a temporary connection to a friend's PC. 4 have a technician repair your phone.
Nov 25, 2011 | Samsung SGH Cell Phones
Can I transfer pics from the camera just by using the port connec
Yes. I understand you?re interested in transferring the pictures from your camera to your computer via USB cable. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer
Jan 25, 2010 | Kodak EasyShare M853 Digital Camera
I was running updates with my phone connected to itunes on my computer, power went out during the middle of syncing. now it wont turn on. i hold both buttons and the apple icon appears for about 5 seconds...
Open up itunes first.
You need to restore iphone in DFU mode.
Restart computer and use a different USB cable if possible.
Hold power button 10 seconds, don't let go, now push in home button 6 seconds.
Now release only the power button.
Keep holding 'home' button until itunes sees it and allows you to restore.
click restore.
If this still does not work then do all of this on a different computer.
Dec 21, 2009 | Apple iPhone Smartphone
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 | Cell Phones
Dell D600 Issue with integrated NIC freezes computer randomly
Are you running any virus programs and firewalls?
If not you should be, and it appears you have some kind of infection and your computer slows down when you are connected to the Internet via the LAN cable.
Run your virus program and scan your computer for infections.
May 23, 2009 | Dell Latitude D600 Notebook
Samsung sgh-j600v
hi im josh in cebu phils.may i help you?
Friend if not recognized by the pc im sure the problem is in the connection because XP O.S. auto detects usb.
To solve the problem:
1.Check the usb port of the computer you are using
2.Check the usb cable from your phone to pc be sure there is no cut.
3.Check the usb port of your phone so as the connection. and the setting be sure the usb is enable.
Good luck friend hope i helped you.
Mar 14, 2009 | Samsung SGH-J600 Cellular Phone
Iphone 3g error 13
Hi friend:
Don´t use front USB hub from computer.
Try rear USB ports.
If you are using laptop, try on diferent computer.
Regards
Aug 19, 2008 | Cell Phones
Memory card to pc
dear friend,
 first of all u go to settings,,,then press .....usb settings..option,,
press...memory card option,,,
then connect ur phone to ur pc through data cable.................
or
2nd option..............
if u have motorola software cd installed in ur pc,connect ur phone through data cable ,,go to options images or music,,press on memory card option,which will come once u press my phone option .............
check it ,if u had still any problem ,mail me at [email protected],,i will be happy to help u dear
Jun 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
107 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
