Question about ASUS A8N-VM Motherboard
Freezing 2.2 amd 3500+ 1 gb ddr 433, 7900gs Nvida card and it freezes on the lamest games, the CPU also runs at 100% on these games and stays there until it freezes. i have had best buy run diagnostics on it and found nothing. i dont know what to do. everything has been updated i downloaded drivers off the net and i re-flashed bios i think i have tryed everthing so if you have an idea please give me more than one:)
  • LEG3NDARY Oct 16, 2007
    FIXED IT. I replaced the RAM with some mushkin RAM and problem solved.
  • 23 Answers
There must be problem with the agp card. please check whether the card is getting heated. if not replace the card and check out
Posted on Oct 06, 2007
Assassins Creed iV Settings : Very Low But I cant run it good
Does your machine qualify for or above the minimum specification to run the game in all departments?
Minimum system required
CPU: Intel Core2Quad Q8400 @ 2.6 GHz or AMD Athlon II X4 620 @ 2.6 GHz CPU Speed: Info RAM: 2 GB OS: Windows Vista SP or Windows 7 SP1 or Windows 8 (both 32/64bit versions) Video Card: Nvidia Geforce GTX 260 or AMD Radeon HD 4870 (512MB VRAM with shader Model 4.0 or higher) Sound Card: Yes Free Disk Space: 30 GB
Jan 25, 2014 | Activision Spider-Man: Web of Shadows for...
I can install windows 8 on MY pc?? cpu:amd sempron
I don't think you can run Windows 8 on your system.
What Microsoft say are the minimum requirements for a system to run Windows 8 can be found here
http://windows.microsoft.com/en-GB/windows-8/system-requirements
First, the processor needs to have certain features - SSE2, NX and PAE which I don't think the Sempron 3000+ has; and you be able to run only the 32-bit version if could run that because you don't have enough RAM, and your processor is a 32-bit processor.
Secondly, the 9250 isn't up to it. It doesn't have WDDM drivers, because it's not a true Direct 9X graphics card; it not being a DirectX 9 card is enough to preclude from running Windows 6 anyway.
Your processor, RAM and graphics card might be upgradeable to be able to support a 32-bit version of W8, but that may be more expensive than buying a (new) W8 computer anyway.
Anyway that's what my brief study of the topic has lead me to believe. It's a no.
On the other hand, see these:
http://answers.microsoft.com/en-us/windows/forum/windows_8-windows_install/amd-sempron-3000-for-windows-8/9b9c1659-63dc-4069-99fa-eb8e08040738
and
http://www.tomshardware.co.uk/forum/id-1806278/install-windows-cpu-amd-sempron-3000-ram-512-ddr-ddr-gpu-radeon-9250.html
(found by searching the internet with "running windows 8 on a sempron 3000+")
They say "Yes".
So I think more research needs to be done. Note the second article says the system will have terrible performance.
20.April,2014
Sep 19, 2013 | Computers & Internet
HP h8-1450 PC is freezing
The most likely problem is a Virus, or program incompatibility. Run a good virus checker (such as MalwareBytes) . But also look at the system cooling(unlikely) check the CPU fan and the case fan if you have one. If you don't have a case fan you should get at least one. The FX6000 series can run quite hot. You don't say what program you are running when it freezes, If you are gaming you should run as many fans as you are able to fit. You don't say what Graphics you are running, games are very processor intensive and so the CPU will generate more heat. By fitting a good GPU you will reduce workload on the CPU and so cut the heat generated.
Apr 13, 2013 | NA Hp Envy H8-1450 Desktop PC with AMD...
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
A9250 freezes!!!
what motherboard you have? how much ddr memory installed ? First look how much memory you have insatalled !? minimum for newest games is 1 GB ddr of ram ... update dx ..from microsoft .com. then try to download psyx drivers some games needs this driver to play
Apr 19, 2009 | ASUS A9250/TD128 128MB DDR 8X AGP...
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
Installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
Game freezes
You need more memory in ur grphics card...
Dec 04, 2008 | Acer Aspire 5315 Notebook
Chopppy video / sound in parts of games
Try running the games on lower resolution and frame rate, see if that makes a diffrence.
Nov 25, 2008 | Video Game Consoles & Games
ASUS A8N-VM Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
