Question about D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 Good day, my router has no WAN and Port 1 Signal, still no luck after resetting the router, this happened after a power surge. Can this still be repaired? Thanks for your help...
  • junftan Oct 05, 2007
    No luck, still no signal on WAN and Port 1. What I did is put my modem on Port 2 and connected my pc on Port 4, it worked, just not sure if it will work on my Wireless Connection. Will this harm my router.
  • 3 Answers
Hey there , try this buddy remove all the cables connected except the power cable...do a hard reset upto 45 sec...wait for the power light to be solid green...connect all the cables back...still no go try swapping the ethernet cables...good luck buddy...tell me if it doesnt work.....
Posted on Oct 05, 2007
Link 1 lit up and no more connection to internet
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
No internet through router
** Try this steps
- Check physical connection (Modem=WAN Port, Computer=Port1) *should be hard wired connected*
- Power cycle modem and router for 2 minutes (to turn off the modem and router)
- Check web browser for Internet connectivity
* If nothing happen reset the router for 15 seconds and try the steps again.
Feb 14, 2009 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
Suggest config of DI 524
Are you using a DHCP server for boths sites A & B, or just using static IP addresses for all the PC's ? What is your IP scheme ? Are you using this D Liers just to connect sitenk routers just to connect sites A & B? Sorry for all these questions, I am trying to picture your network before attempting a solution for your needs.
Jul 31, 2007 | D-Link AirPlus DI-524 Wireless Router
Help with DI 524
Start your router, and keep and hold pressing on the "reset" until it resets by itself. This will reset the router to defaults. If the lights got back to work normally again, then you are ready to go. you can access your router by directing your browser to http://192.168.0.1 Admin as user and blank as password Download this manual to get you going on configuring your router ftp://ftp.dlink.com/Gateway/di524_revc/Manual/DI-524_manual_06292005.zip Goodluck
May 25, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
220 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
