Question about Compaq Presario M2000 Notebook
Monitor removal i need to remove the monitor/screen from my notebook
  • 661 Answers
Ok then,  it;s a screwdriver job,
you need to remove the facia plate above the keyboard, and the keyboard itself,
this should get you a visual on the connections for the monitor,  the support screws for the monitor are in the hinges, (the covers for the hinges will need to be removed,
Posted on Oct 11, 2007
TOSHIBA U925T LCD replacement guide?
Well it is not that hard as it seams to be. First catch at Toshiba is plastic overlay above the keyboard it is cca 10 mm thick you should remove it with the screw driver carefuly. when removed you'll find screws unscrew them. After that remove hard drive and remove the cover for ram slots. Then remove all screws from the bottom side of the notebook. After that turn the notebook on the right side as you would do it normaly when using it. Remove the keyboard. After that remove all screws that you'll find under the keyboard. When done carefully remove the upper cover of the notebook. After that dismount the cables that come from the monitor to the mainboard and remove the screws holding the monitor brackets. Then you'll be able to remove the monitor. The monitor has litle rubber circles in every corner remove them. You'll find screws under them. Unscrew them and grab the plastic border of the monitor from the inner side and pull it towards you. So now you have removed it and the only thing that has left is to remove the side brackets you'll see little screws from the side - remove them and also remove the signal cable from the back of the monitor. When done take new monitor and do the reverse procedure.
Feb 07, 2014 | Toshiba Satellite U925t
How do i replace a broken laptop screan
Take out Battery
Remove screw covers on monitor
Remove screws
Remove plastic Bessel around screen
Remove screws at top screen assembly
Loosen screws at bottom top screen assembly
Remove video cable behind Screen
Remove screws on side of the screen
Remove webcam cable
Remove video connector
Found it on this video:
HP ProBook 4525s Notebook Screen Replacement Procedure
Feb 04, 2014 | HP ProBook Computers & Internet
Hannspree notebook lcd screen broken
should be screw on front or back,,if front there under rubber groments,,,pull them up/ off with flat head,,to reveal screws,,
Dec 20, 2011 | Sony Computers & Internet
I am starting the laptop but is not starting , the screen is black
This could be due to a loose connection where the LCD screen connects to the mainboard. Test this theory by connecting a monitor to your Notebook via the VGA-out port on your Notebook. If it works and shows a picture then your Notebook is ok and the connection or screen needs to be looked at. Use a friends VGA monitor.
However if nothing displays on the monitor through the VGA out-put then the computer will need to be taken to a notebook computer technician to diagnose and repair the system. Claim warranty support if you can.
Take care
damnor01
Sep 23, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Monitor broke
Go to Ebay, (Computers and Networking>PC Components>For Laptops and Notebooks>Screens,LCD Panels>Emachines D620)
Or here is a website I found,
http://www.screentekinc.com/eMachines_D620-5777--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is information on removing the old LCD screen,
http://www.sparepartswarehouse.com/LCD-Removal/laptop-lcd-screens-repair-removal-instructions.asp
Another one,
http://www.screentekinc.com/lcd-removal-instructions.shtml
Jul 19, 2009 | eMachines eMD620-5133 Notebook
Gateway PC Notebook/Tablet Model: CX2618 Monitor Replacement
First shine a flashlight on the screen. if you can see a very faint image on the screen the problem is the backlight. If not... it could be a few other problems, first test if it works on an external monitor. If it can then you need to cleear the CMOS. to do this you unplug the cord remove the battery and hold down the ON button for 30-60 seconds, then turn it on. If it does not work on the external monitor it is probally because you have a bad video card and need to replace it.
Jan 28, 2009 | Gateway CX2618 Notebook
When I start up my computer, the screen stays black. However, the light flashes indicating that it is working, and the computer makes the starting sound.
Test your notebook with an external monitor attached to the VGA port on the side of your notebook. If both internal and external monitors have no image, this problem is not related to the notebook screen.
It could be memory related problem. Try reconnecting the memory module. If you have two modules installed, remove them one by one and test the laptop with each module separately. It’s possible that one of the memory modules is bad and your notebook will start as soon as you remove bad RAM.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
Replacing the whole monitor screen and bezel
Usually there is a plastic cover that snaps off right about the keyboard that covers the hinges. It is sometimes screwed from the bottom of the notebook thought. Once that is removed you should have a clearer view of what needs to be done. Sometimes there is a few screws from the bottom or back of the system that hold the hinges and sometimes the screws are on top of the hinges. You should also see all the cables that go from the screen to the system, unplug those. Hopefully that is all you need to do, but sometimes you have to remove the keyboard and palmrest to get the screen off. Good Luck!
Jan 10, 2008 | Gateway MX6448 Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
