Question about HP LaserJet 1022 Printer
Unable to connect to printer
Sir, i have installed hp laserjet 1022 on client machine and my problem is that after some time ie 2 or 3 hours on another client machines the printer status shows unable to connect so ican not print from other client machine for solving problem i usually restarts machine and problem is solved for again 2hours but after some time same problem arises i also have hp printer on same network but this has not accured this type of problem so idont think their is problem with my network so kindly assit me in solving the problem
  • navinc9 Oct 12, 2007
    so it is fixed that their is problem in network and should i try to repair 2003 server
     kindly suggest a permenant solution for the above said problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Actually it may be a network problem. I have had 10-15 machines go down and lose the printers at the same time in a hospital and the sloution was to turn them all  off and on to reset it. Sometimes it would happen 3-4 times a month. A glitch in the network.
Assuming these are all network printers.
Posted on Oct 11, 2007
  • CheckitRight
    CheckitRight Oct 12, 2007
    There may not be anything you can do, I have done nothing more than what I told you turn on and off they have been working fine for now. It also could be the application you are running in hte hospital we use Meditech which is a special programm for all hospitals and sometimes they freeze up.
    All I can suggest is this:
    Check and make sure all printers have
    1- an IP address
    2-printer name
    all must be different from each other ( unless it's a shared printer)
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
I want to use a HP LaserJet 1018 printer on Mac pro
I'm sorry. It appears HP does NOT support Mac for this model printer
Mar 28, 2011 | HP LaserJet 1018 Printer
How to change teflon in hp laserjet 1022 printer
hi sir
i have to information about how chage the hp1010 lasr jrt printer teflon
so pls told it
thank's.
my cell nn+919890756845
Mar 03, 2011 | HP LaserJet 1022 Printer
LaserJet 1022 Printer: After installation Hp laser 1022 printer itts show...
Make sure the cable from your printer is properly connected to the CPU
Make sure it is well recognized.
On start menu, click printer and faxes..
you will see your printer model.(if you said its offline then the image of your printer is blurred...right?)
Now right click on the printer model.. and click the "Use Printer Online"
After that you will see that the image of your printer is clear with the word "ready"
Try to print again.
May 16, 2010 | HP LaserJet 1022 Printer
Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Feb 09, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Mac won't add HP LaserJet 1022
download the software on hp.com type the printer version and the model
Feb 01, 2010 | HP LaserJet 1022 Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
I got the error '' Unable to connect the printer , access denied , printer could not be started'' . I have a XP home m/c to which i have connected HP 1022 printer. I have shared it with all machines in the...
Are you on the same network as the host machine. In simple terms, the machine that you are trying to printer should be on the same network/domain.
click on start, right click on my computer and go to properties. Under properties check the computer name tab. specifically the workgroup. see if that matches the host machine. If it's different that's the issue.
If its different click on the button change, and type the domain in the box below.
hope this helps.
Feb 17, 2009 | HP LaserJet 1022 Printer
Rate of Taflon for Hp Laserjet 1022
no idea what you are saying , taflon no make sence
Dec 29, 2007 | HP LaserJet 1022n Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet 1022 Printer Logo
219 people viewed this question
Clive
Clive
