Question about Intel D945GCZLKR (BLKD945GCZLKR) Motherboard
Regarding sound problem in my pc
See i dont no automatically in my computer sound is not comming what u would suggest me what is the cost of p3 sound card
  • 42 Answers
Re: regarding sound problem in my pc
Either you got to increase the RAM or got to update the audio driver... Update of the latest drivers is usually available in Windows automatic update or you can go to the manufacturer's site and update the driver for sound card... also check if the speakers are fine...
good luck
Posted on Sep 26, 2008
Is this xp if so go to start/run/type dxdiag then click the "sound" tab then test the sound to the left you will see"hardware acceleration bring that down a notch and try that also you may have to update your driver for the sound card you have.Sometimes when you install something you loose the sound.Also try system restore
Posted on Oct 06, 2007
0 characters
3 Points
Does p3 sound cards support in p4 machines
Probably it will not support.But you can downlaod drivers for your p4 from below link:
Enter your motherboard model number and search and download from results.
Jul 15, 2013 | Motherboards
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....and no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)'s quite simple process to fix it, and I am not charging any money, just trying to do some service.
Copy the above address in the browser, replace + with dots....all the best...
Dec 17, 2009 | HP Vectra VL400 P3 Skt 370 Motherboard...
I have esys mother board , my computer dont sound,
you can use realtek sound drivers or if u have *********** board driver cd just simply run the driver c d
automatic system get sound driver
other wise u can search on torrent search engine u can get your sound driver
plz mail me as a reply
Rajesh Sharma
my e-mail address is
Mar 22, 2009 | Intel D101GGC Motherboard
For sound installation
Fiend your solution direct from Gigabyte. Here is your solution.....
Jun 14, 2008 | Intel Motherboard
Changing a P3 motherboard for a P4 motherboard
P-4 boards want at least a 300w power supply, P3 were not so picky. Next, swapping boards is easy but remember to stay in the same form factor, (the relative size length and width) a server board won't fit in a micro case.
The location of the stand offs (where the screw holes are) may have to be changed. P4 boards have 20 pin or 24 pin power connectors so the appropriate power supply will need to be ordered. If you are running a lot of peripherals a 450w ps at least.
Now you decide if you want a board with on board, video,nic,sound,etc.
then you have to order the supported processor/heatsink and fan/thermal grease/supported Ram etc.
I've been doing this for years so i probably left out a lot.
Lately because of costs I've resorted to backward building.
I decided since DDR2 is cheap, find a board that supports that ram in a processor socket I want to use (socket 478-775) etc.
Mar 21, 2008 | Intel Motherboard
Ms 6315 with p3 833mhz freeze
Driver, bios & manual here, click the link.
Your board:
Your chipset is Intel 815EM located at Intels site here.
Personally re-installing your chipset may not solve your problem.
Suggest you either run windows system restore back to a time your system did not freeze or re-install windows. Most PC's that lock up or freeze is caused by programs, some by hardware.
Load your Win CD into the cdrom & just re-install windows only.
Good Luck & Kind Regards.
& please vote.
Mar 19, 2008 | MSI MS-6315 Motherboard
Clock speed
thats older cpy 66 bus mhz slow takes older sdram cost more 512 mb max per slot i would do
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Error present
Hi sathya08,
This sounds like a DMA request failure. I am afraid without more information it may be difficult to accurately diagnose a cure.
I am afraid you will have to take your PC to your Local Guru.
Regards, ajb2000
Dec 28, 2007 | HP Vectra VL400 P3 Skt 370 Motherboard...
Intel D945GCZLKR (BLKD945GCZLKR) Motherboard Logo
57 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
