Question about Canon PowerShot A550 Digital Camera
Memory Card Locked
The camera is not reading any other memory card than the one which was given along with the camera. I tried 512MB, 1GB and 2GB Cards with out any success. But all these cards are working very fine with another Canon PowerShot A540 (My friend's camera). What is the problem? If the problem is with Camera then it should not even read the card which was given with Camera? Please help.
  • Lexy7 Mar 23, 2008
    I am using a canon a540 and was reading in the card in printer and inserted back into camera the screen says card locked. i tried removing it and trying again.. turning on n off and to no avail. i am able to read the card in the printer and see the pictures.. I have been using this card for month and removing and moving pictures to camera. I even tried resetting pics to the original settings .. still nothing.
    would appreciate any help.
    thanks
    D
    Genius:
  • 2,985 Answers
You have raised a valid point if the camera has a reading problem then it would have problems reading all cards But it read the original OK? I think this is best addressed to Canon Support it seems that there is a problem that may only be resolved by them perhaps exchanging the camera for another
Posted on Oct 06, 2007
SOURCE:
Every time I put in a new memory card (this time I put in a 2gb Sandisk memory card) in this camera it always shuts off and I have to take out the batteries to get it working? What's wrong and what should...
My 33LF had the same problem with a 1gb Memory Card. I have replaced it with a 512mb card and it seems to be working perfectly. I was told that the capacity of the 1gb card exceeds the capacity of the camera.
Dec 09, 2010 | Pentax Optio 33LF Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Kodak DX7590 not reading memory card...
hi. if you can open the camera specially in cards slot, try to desolder and resolder the card slot.some time the loose contact of the pin between the board and cardslot are cause of problem like fromat your memory card,cardlock and not readung the memory.
goodluck my friend
Jul 13, 2010 | Kodak EasyShare DX7590 Digital Camera
Problem with olympus digital camera d-395
The problem is that the largest xD card that your camera can support is a 512mb card without the letter M or H in front of the 2gb. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there are no plans to upgrade the camera to allow those types of cards to be supported.
Apr 29, 2009 | Olympus Camedia D-395 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
New Memory Card
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb card is not compatible.
The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Jan 01, 2009 | Olympus Camedia C-350 Digital Camera
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
2 gb memory card
quoted from Fuji USA's site: Compatible with the 1GB,512MB,and 256MB except 2GB xD-Picture Card TypeM / TypeH
http://www.fujifilm.com/products/digital_cameras/accessories/card/index.html#compati
Dec 28, 2007 | Fuji FinePix A345 Digital Camera
Slvr L7 Memory Card Problem
I know for a fact that the slvr l7 will support 1 gb due to the fact that my slvr currently has a 1g sandisk card in it that functions perfectly
Oct 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Canon PowerShot A550 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
