WLAN connection I'm not able to connect the WLAN on my laptop to my wireless internet router. It just keeps saying that the WLAN is disconnected.
  • 3 more comments
  • Anonymous Nov 03, 2007
    Black with the Acer logo on the cover
  • enjolie Nov 10, 2007
    i restored my compaq v2000 and eversince then it tells me that the lan is disabled and wont let me enable it..the ethernet port isnt even working
  • Anonymous Nov 13, 2007
    I'm having trouble setting up my aspire 3680 and a belki 54 wireless router it comes up- the wireless security settings on this computer do not match the settings on the belkin 54 g. Please could you advise on how to set this please.
  • clinta74 Nov 19, 2007
    Acer 2680-2682. Worked for 30 days until I found out that the Vista Upgrade disc that came with the computer was just a 30day trial with no method of uninstallation. Got reinstall discs from ACER. Now it sees wireless networks, connects and immediatly disconnects saying network unavailable. LAN works fine. All firewall settings are turned off.
  • wheelmanhwy3 Mar 27, 2008
    worked fine for 45 days, then began to fail to find wireless router, turn on and off switch for 802.11b, within a week i then had to go into control panel wireless and get it to connect , now the light comes on but cant find wireless router at all...
If you have an Acer Aspire running windows Vista, make sure you enable security as a minimum of WAP on the router; when I did, the network connection worked.
Posted on Dec 02, 2007
    Problem Solver:
  • 5 Answers
Make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Posted on Oct 04, 2007
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
How can i turn on wlan on my router? would this be the reason laptops will not connect to it?
By default, the WLAN on your router is enabled. This is the setting that will give wireless computers wireless internet connection.
Sep 17, 2010 | D-Link AirPlus DI-614+ Wireless Router
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
May 05, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cannot connect to internet via wlan but can lan
The only thing that seems to be missing here is did you try another wireless card? If its built in you can get a usb wifi or pcmcia type. That will probably get you back online via wifi.
Dec 15, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Computers & Internet Logo
1,109 people viewed this question
Alun Cox
k24674
