Sound proublem in TV (Thomson make)
During watching the TV, sound of TV goes off, after some time sound is recover it self for a short time. but when blowing the fan air on surface of TV then sound goes OK.
  • brentbell Oct 23, 2008
    RCA 35" TV- There is a click and the sound quits working. Unplug the TV and let it sit for a while and the sound comes back, only to shut off after varying lengths of time. I read the possible solutions, if it's a bad capacitor I can replace it, just not sure which is the sound board, though I guess I could follow the speaker wires:) Any help would be appreciated, as the picture is otherwise flawless.
    New Friend:
What to do
Posted on Dec 29, 2013
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
1 it might be due to spraker wire loose or its connector loose. 2 loose contact in sound section. 3 some cap faulty. 4 sound ic might be grtting more supply so ic is getting over heated. 5 sound ic might be defective.
Posted on Oct 06, 2007
SOURCE:
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
What is reco referring to
If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again,,,,sounds like it's time to change the battery..
Nov 16, 2012 | Casio PAG40-3V Wrist Watch
Picture on screen disappears and horizontal light appears in the middle of the screen
you need to replace the vertical transistor of your tv. be careful if you want to try to fix it your self. there's high voltage inside the tv.... u need to call the technicians. the transistor won't cost you too much. it's pretty cheap. safety first. good luck
Jun 14, 2012 | Thomson Televison & Video
Hello My "Thomson DT16300 Top Up TV+Digital TV
Try a Video cleaner, and go to "Thomson" website.
Aug 03, 2017 | Thomson Lyra PDP2840U MP3 Player
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Compass comes up with RECO, what does this mean?
If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again.
Mar 20, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Rca direct view tv 36" f36665
clicking,w/no sound or pix is usually IHVT, AKA flyback transformer.Please clarify size and model #. Include last three characters in Thomson products service #---Ex.=F36665-YX01.
Oct 02, 2007 | RCA 32F531T 32" TV
Tv shuts off while watching
replace EHT (extra high tension) transformer
Feb 07, 2007 | Philips TS3661C 36" TV
Televison & Video Logo
379 people viewed this question
Top Televison & Video Experts
Ekse
