Question about Fuji FinePix S7000 Digital Camera
Scrambled focus of all subjects
Camera has been great--not abused or dropped--during a football game, started getting horizontal lines through my lens (was using LCD at the time); appears to "scramble" or distort anything I point the camera at. Never had this happen before. Problem was intermittent for a week or two; now seems to be permanent problem. It sees the subject but distorts it greatly. Have tried new batteries, re-formatted cards, etc. Problem is more likely in the lens I believe but have no idea what is wrong. Any ideas on what is wrong and how to correct it? Thanks Vick
  • Anonymous Dec 06, 2007
    Similar problem. Tried resting the camera and resetting mose of the features. Removed batteries and changed memory could not resolve. All functions worked except saved picture and horizontal bars and finally a white screen with dark bar on bottom.
    Returned to fuji for repair out of warranty $160 about two weeks total.
    No problems since about 20,00 photos with camera.
    Problem Solver:
  • 9 Answers
Hello there I was having that same problem with my S7000 before my CCD sensor stopped working, the horizontal lines i had were black and blue. Hope you dont have the same problem as me.
Posted on Oct 23, 2007
I had the same problem.  What cured it for me was going into setup mode and changing almost all the funtions.  Like changing adapter to yes, frame No. to renew, and ccd- raw to on.
Then moving throught the the auto, sp, Movie funtions, and repeating the move to setup and changing the adapter to yes, frame No. to renew, and ccd- raw to on, until my camera started focusing on it own.
I had given up it and was going to send it for repairs but it works fine now.
Posted on Oct 24, 2007
SOURCE:
I dropped my camera and got the lens error e32 message. The lens was misaligned at first, but I straightened the lens out, so it did retract back in. Now, the problem is, when I try to take a picture, it...
Take the camera to a specialist repairman! It sounds like the impact when you dropped it, (or when you straightened it), has damaged the internal parts and electronics.
Jan 16, 2018 | Canon PowerShot SD1400 IS IXUS 130...
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
My wife has a nikon d70 with a quantary 28-200 zoom lens. F2.8-F5.6. It takes great picutres during the day. At low light and nightime the longer range pictures will not stay in focus. She set the focus...
The camera is unable to focus properly in low light at long focal lengths. You might have to throw some light on the subject with a flashlight until the camera locks in the focus or resort to focussing manually.
Aug 11, 2009 | Nikon D70s Digital Camera
I can not get my canon eos rebel k2 focus on a
Autofocus is activated by pressing the shutter button halfway, be shure to have a EF lens in the camera, otherwise it won't make autofocus, put camera on full auto mode or "sports mode" (the running guy) and the focus settings on redictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
Jul 10, 2009 | Canon Photography
My nikor lence is not focusing . its made crazy just serch for focusing but it cant so what can i do for it ?
The 18-70 is a rather slow lens and needs quite a bit of light before it will focus. Also, the lens needs contrasting between subject and background. For instance, if you try to take a picture of just the blue sky with nothing else in the frame, it will probably not focus at all. Put a plane in there as the subject and you should get the shot.
See if you experience a better focus outside during the day with some good contrast between subject and background. If it works better, then it's just the limitation of the lens. If it's still not focusing, there might be a problem with the lens. You do have the lens on M/A (auto focus) right?
Mar 27, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Blurred subject in middle of photo
I own Rebel XT and Canon 50mm f1.8 MKII lens with plastic mount and noticed many pictures with missed focus, either front or back focusing. Meaning objects slight forward or below the intended subject is in focus. I've sent my body and the lens to Canon for evaluation and thet adjusted my focus sensors on the body. I still have problems and there are many threads related to focusing on this camera with 50mm f1.8 that the sensors on this camera do not do so well with fast lens and prone to missed focus.
Test your camera's focusing ability with a book or magazine where you focus on just one specific line and see if it is truly in focus when you review the picture.
Feb 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40X What is the best setting for night pictures at a youth football game (under lights) My pictures are not coming out focused and very dark
It will take a little experimentation on your part, but you are likely to get the best results by turning off most of the automatic features on the D40x.
First, for exposure, a lighted field tends to have pretty even lighting across it. You still need a decently high shutter speed to capture football action, so you will need a high ISO setting.Turn your D40x mode dial to "M" for manual (see p.43 of your manual). Set your ISO to 1600 (see p.37 in the manual).
Consulting my 1973 Kodak Master Photoguide, I'd suggest using an initial starting point for your exposures to be a shutter speed of 1/400s ("400" on the LCD) and and aperture of f/4 on your lens (p.43). If your lens is slower than that, equivalent starting points would be 1/200s at f/5.6 and 1/160s at f/6.3. For best results, though, you will want to use a faster lens for night sports.
Take a picture of a subject on the field, then display it via playback. Click the multi-selector up or down until you see the histogram display. While most of the bars in the histogram may be toward the dark end of the scale, there should be some in the mid-tone region representing your subject. If everything is toward the dark end, you will need to open your aperture or reduce your shutter speed. If there are bars piling up at the extreme right or light end of the histogram, you can increase your shutter speed. Continue this process until you find the exposure setting that gives you a clear-looking picture on playback with a good histogram. You should be able to use this setting for the rest of the evening. It pays to check occasionally, though, as sometimes lights either increase in brightness with time, or some lights may go out.
Concerning poor focus: if you are using a telephoto lens under low light, the camera autofocus mechanism can either take a long time to focus, or may fail to focus. This is another case where you may get better results going manual. If you are using an AF-S lens, there should be a switch on the lens marked "A <-> M". Switch it to the "M" position and you will now focus the lens manually. You will turn the focus ring until your subject appears its sharpest in the viewfinder. If you can predict where the action will be happening, you can pre-focus on the spot and wait for the play to unfold and take the picture when the players get there. Choosing moments when players naturally have minimal movement in the midst of action is something all sports photographers learn, so as to make the most of the small action-stopping ability of shutter speeds in low light situations, such as when the quarterback stops to throw a pass, or catching a receiver at the topmost height of a jump.
Remember after the game to restore your usual settings to the camera: a more moderate ISO setting, selecting the "P" or an automatic mode on the dial, and turn the switch on your lens back to "A" for automatic focusing.
Sep 27, 2008 | Cameras
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Blurriness
This is a great camera! Are you using the focus guide to focus on your main subject. Move the camera until your main subject is in the bos ten depress the shutter button 1/2 way down to focus the subject. Leave you finger there at the focus point-You can then move the camera to take in more objects or people and gently push the shutter all the way down. Generally, the causes of out of focus photos are:
the camera in the wrong mode-just start with the general mode-usually a little camera symbol
do not change any settings-if you have go to the menu button and settings and go back to default settings
the focus feature of the camera 9explained above is not being used
You are too close to the subject (use the zoom instead)
You are experiencing camera movement by pressing on the shutter too hard or moving your hands. A tripod always works best.
You can go to www.panasonic.com and obtain a manual for your camera if you do not have it.
If your camera still gives you blurry photos, please get back to me with any info that might help- have you dropped it or gotten it wet or anything like that?
Thank you for using Fix YA and please don't forget to rate me!
Aug 18, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
217 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
