Question about Archos 604 WiFi Digital Media Player
Archos 604 wi-fi
I bought yesterday archos 604 wi-fi, i charged it about four hours and the battery didn't charged, what can i do?
  • 33 Answers
It's sounds faulty, take it back to get repaired.
Posted on Jun 14, 2008
Can I charge archos 604 batteries using dvr station and power outlet?
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Sep 09, 2010 | Archos 604 Digital Media Player
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
if you wouldnt mind losing data then i suppose you could format it and get rid of the firmware update and the put all your stuff back on. only a suggestion.
Oct 27, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 hard drive problem
there is a nice pictorial dissasembly at this site:
Sep 01, 2008 | Archos 604 Digital Media Player
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Aug 09, 2008 | Archos 604 Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Archos 604 wifi
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Jan 11, 2008 | Archos 604 WiFi Digital Media Player
Battery problem
I might have got this wrong but i thought there a fix you could download from the Archos site,i had the same problem with my mate's one only got to watch 1 and a half episode of the tv series of Heroes,i also ordered a battery type charger that could give it up to 2-3 charges while you travel.
Dec 03, 2007 | Archos 604 WiFi Digital Media Player
No power going into my archos 604
If the unit was dropped, you may have to replace the battery. The batteries for those units are lithium-ion-polymer and are somewhat fragile when dropped. The other possible reason it is not working is that the shock form the drop has "bricked" or killed your unit's internal circuitry. I would also try charging it with another USB connection as the USB connection you are using may not be powerful enough to charge the unit. For more detailed help you can try the forums at There are many technical experts concerning Archos Units at that forum.
Aug 08, 2007 | Archos 604 Digital Media Player
Archos 604 WiFi Digital Media Player Logo
85 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
