Video Game Consoles & Games Logo
Kent Ballard Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have xbox360 slim. Two games i just purchased from a craigslist ad MW3 and Battlefield 3, both games have no scratchs on them. The system will play games for five minutes (time does not include prelude into the game, which for both games play flawless.) Afte you have taken control of character the game will stop with an error code that says cannot read disk, clean disk and restart xbox. I have had both games cleaned/resurfaced at game zone, in whitch returned the same error code at the same time. Are the games no good, if not what causes that. Other games work perfect even games with light to medium scratchs play all the way through without a problem. Tahnks for your feedback
winserp
Level 3:
Master:
  • Master 363 Answers
  • Posted on Nov 03, 2016
winserp
Master
Level 3:
Master:
Answers
363
Questions
0
Helped
207443
Points
1105
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
mick mack
Level 2:
  • Expert 86 Answers
  • Posted on Nov 08, 2013
mick mack
Expert
Level 2:
Answers
86
Questions
0
Helped
29797
Points
172
Hold the disk to light and look for pinholes through the silver layer.
3 Related Answers
Anonymous
  • 152 Answers
  • Posted on Nov 21, 2008
SOURCE: had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Anonymous
  • 223 Answers
  • Posted on Jun 01, 2009
SOURCE: Freezing Game
try checking the game for scratches and fix accordingly...the system wouldnt hurt to be cleaned as well, just remember to use an air canister.
Anonymous
  • 1093 Answers
  • Posted on Jan 27, 2010
SOURCE: Brand new game, Xbox continually gives me read errors.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
The Wii sports resort will not let me out of instructional video to start playing game. I did not buy Wii motion plus accessory to go with it. Playing it on my will system
buy battlefield 5 cd key, battlefield V cd key, buy battlefield 5 beta cd key, get battlefield 5 cheaper, battlefield V beta keys, battlefield V key, battlefield Vietnam cd key, battlefield V brigin cd key
https://www.m8x.com/cdkeys/battlefieldv.html
tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
2answers
Battlefield 3
Running the new Battlefield 3 game doesn't require any of the earlier versions, so your problem would likely lay elsewhere. Be sure you have a connection to the internet, and try running the game again. It may need to install the patch software fresh again.
Why will my xbox let me play some games but not other on live when i used to be able to play them all?
Check all X Box games for scratches on the surface of each CD Disk.
Keep in mind, each game CD is read by lens Laser from the inner then to the outer edge of CD Disk.
Most people believe CD's are played like a record, from the outer edge to the inner.
If there are scratches, CD may be damaged beyond simply cleaning.
All cleaners and methods of cleaning are not the same.
Contact the manufacture of the CD to find out the best method of cleaning
or possibly repairing so game can be played.
If you CAN play some games and NOT others, this rules out a Laser Lens Player fault condition. Look for a reason of the CD will not play in the Laser Lens Player.
Here is the top 5 reasons CD's will NOT play.
1.) CD in inserted into player wrong way?.
2.) CD surface is dirty or dusty?.
3.) CD is possibly warped or bent?.
4.) CD surface is scratched?.
5.) Wrong CD/ or format for CD player?.
Hope this lists helps!
FASTESTNASCAR
My xbox360 is saying for battlefield bad company2 clean the disc and restart my console i have done that 5 times but it did not do it
You might have a minor scratch that is impeding the disc from playing. I had that with a game or two before. Try getting the same game from someone else and installing it on your hard drive. If the game is installed, it only needs the broken disc to start the game, and then the rest will run off the HD.
Every time i try to find a game on battlefield bad company 2 it says couldn't find a game
You might need to update the game. Did you download the Vietnam package? you don't need to purchase it but you do need to download it in order to be able to play online again.
4answers
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
