Question about Whirlpool GEW9250 Electric Dryer
I have a duet dryer
Sometimes when I start the dryer , it shuts off and E1 flashes on the panel, why would it do this
  • fast ed Nov 10, 2007
    Dryer keeps shutting off, flashes "E1". Sometimes I'll hit start as it flashes and it restarts. Sometimes finishes cycle. Sometimes not. I notice it shuts off more as the load is wet/heavier. Any suggestions??
  • jonneeboy Jul 12, 2008
    I turn on whirlpool frontload dryer...turns for about a minute and stops and flashes E1
  • 209 Answers
Faulty element?
Posted on Oct 15, 2007
SOURCE:
I have model # GEW9250PW duet front loader dryer and keep getting a code E1
This is a failed thermistior error code.
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
? Door - must be firmly closed
? Press Control On
? Press End Of Cycle Signal (Louder)
? Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
? Unplug dryer or disconnect power.
? Check wire connections at the machine
control electronics and thermistor. See
Accessing & Removing the Electronic
Assemblies, page 7, and figure 8 for
thermistor location.
? If wire connections are good, remove the
two wires from the thermistor and replace
the thermistor.
the part number is 8577274 you can remove the lower panel in the front to change the part.
thanks and please rate me thank you....ken
Jun 07, 2011 | Whirlpool GEW9250P Electric Dryer
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 25, 2010 | Kenmore HE5
The dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
E1 or E2 Thermistor Failure
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpoo Duet Dryer is flashing an error code of E1. What does this mean and what is the fix?
E1 Thermistor open Replace thermistor if found defective
replace the thermistor on backside of unit behind back panel... i think its part number 8577274 you can find this on repairclinic.com, or searspartsdirect.com, or you can shop locally, let me know how itt goes
Mar 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet error code e1
Whirlpool Duet E1 Error
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 02, 2010 | Whirlpool GGW9200L Gas Dryer
Whirlpool duet dryer runs and heats well for 4-5 minutes then shuts off. it has a light that flashes E1. what is the problem??
E1 THERMISTOR OPEN "E1" flashes if the thermistor is open.
Check your wire connections on your thermistor and your control board. If they (connections) are good you should replace your thermistor. If you would like more detailed instructions in performing the "THERMISTOR TEST" post back here and I will find you a manual or find a way to scan you mine. Or, you can merely remove the top of your dryer and inside you will find the TECH SHEET giving you detailed instructions on this test and many more.
Cheers
Dave
Jun 07, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer shuts off and E1 code shows
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.Does the E1 error represent failure of the thermistor,
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off. Some pics at this link:
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
hope this helps.thanks and Godbless .appreciate by rating as fixyaa
Oct 17, 2008 | Dryers
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
screen.
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
