Question about EnGenius EUB-362 (EUB362 EXT) Wireless Adapter
Frequent loss of all operation.
I've owned two of these devices now, and have the same problem. The device starts fine with windows xp. If I leave the connection alone completely, the signal strength remains constantly in the green, and all seems normal. However, once I start transmitting data with it (ie accessing online material) the device loses all signal after about three minutes. I'm in an area with a multitude of other networks running besides the one I'm using. I mention that because when before the device loses signal, I can recognize up to 6 other signals. Once I lose the signal I'm connected to, I also can no longer see any of those networks either. Using the repair function does nothing. Disabling/enabling the device fails because once I disable the device, the device manager is unable to restart it and gives the error code 10(device unable to start) The only way to reconnect is to unplug the device completely, plug it back in, and start the process over again. I have updated the driver and the software. This is happening with both devices of the same make and model. Thanks for your time :)
  • 1 more comment
  • Anonymous Nov 15, 2007
    i am also having a similar problem. constantly loosing signal and having to unplug or reboot to fix. also my computer freezes frequently with the device plugged in.
  • tpage7 Nov 24, 2007
    This things been a failure for me too.Intermittent network connection an inconsistent performance problems just 8 days after receiving it.Same troubles as Armtdawg.I've tried every software an driver configuration i could think of while physically repositioning it and nothing works.Some Neweggs' buyers reviews are saying the same thing so its just a bad piece of hardware.I'm going to end up returning mine.---tpage7
  • Royston Ferguson
    Royston Ferguson Jun 07, 2008
    Exactly the same problem. Just sitting there not surfing, the device wlan client utility shows full green and excellent connection. but the moment I try to connect to the web the signal either reduces or drops completely. Sometimes when I unplug and replug, the pc doesn't see the adapter and I have to reboot the pc.
Get a cooling sticker pad from 3M and paste it at the back the PCB board of the 362 ext.
There is a newer version of driver , version 2.1 for windows XP.
Posted on Jul 25, 2008
The device refuses to work with usb2.0 ports on 3 different pc's.
The connection drops after 3 minutes and disappears from the site survey screen.
Engenius technical support claims they never heard of the problem before.
The only fix I found was to get into xp device manager and disable your enhanced usb
controller.Then with usb v1.0 the eub-362 works forever without a hitch.
Posted on Jan 07, 2008
  • xtgold Jan 09, 2008
    Search the earth for the nub862_362_xpv1-7 driver and install that.
    It's the only driver I could get usb2 to work with.
    My present usb2 controller has the intel 82801EB,your mileage may
    vary with other chipsets.
Are you using the client software that came with the unit? If so, do not use it, use the native windows connection client, just use the drivers only.
Also make sure you have it DIRECTLY connected to your computer and not a hub, it seems to work best this way.
Finally under System Manger, make sure it is connected to a USB 2.0 port.
Posted on Nov 21, 2007
I've got Acer 5560g and when i plug in it memory stick or external hard drive in any of the usb ports it work fine only for a half minute , sometime is less , after that the device disappear and
could need a driver update and a good clean it might be malware or virus
Download and install at least one of these all free depending on your operating system Freeware detect and remove a multitude of adware files and modules. Bitdefender Mobile Security Free Download Information: All Freeware is not responsible for freeware you are downloading nor for details provided about the freeware "Bitdefender Mobile Security 1.1.593" listed here, as the developer can modify information without notifying us. Even if we try to check the files for viruses, we cannot guarantee that they are safe and clean. For your own protection always scan downloaded files for viruses, spyware and malware. avg free 2013 microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit anti malware free edition Win XP/2003/Vista/Windows7 malware protection windows xp microsoft security essentials windows 7 microsoft security essentials Hope this helps.
Jan 08, 2013 | Computers & Internet
How to disable usb mass storage in windows xp
To disable usb ports we have to do some registry settings and change the key to 4.
"Warning : Serious problems might occur if you modify the registry incorrectly by using Registry editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. If a USB storage device is already installed on the computer"
Follow these steps:
1: Start the registry editor from start menu by typing regedit in Run dialog box.
2: Navigate to HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/UsbStor
3: In the right pane, double-click Start.
4: In the Value data box, type 4(if 3 is there,change the value 3 to 4), click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
When you do so, the USB storage device does not work when the user connects the device to the computer.
on Mar 17, 2010 | Microsoft Windows XP Professional for PC
Logitech M510 suddenly stopped working
What does the device manager say about the hardware?
It could be loss of the usb device controller. Windows XP is old and that is an indication that the hardware is old too.
Mar 25, 2017 | Logitech M510 Wireless Laser Mouse
Can't Recover Vista CD ROM Device Driver
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
Mar 09, 2012 | HP Presario Computers & Internet
My computer frequently stops responding, specially when i minimize windows. My screen usually leaves annoying images. I think it freezes that way. I've checked the device manager, my windows...
How much memory does your computer have? Alot of times when the temporary memory gets full everything will slow down and will cause applications to stop responding.
It can also be your hardrive is too full. The more space you use on your hardrive the slower it will go and if you fill it too full it will also make programs stop responding.
Sep 15, 2011 | Microsoft Windows XP Home Edition
Cannot connect to internet router is working properly it is connected to my regular computer but cannnot get singal for my notebook
Hello, bevybuns5!
First thing, make sure your WLAN card is turned on, however, without knowing your specific laptop model, I can't help locate it for you. After that, check your router's wireless security code, and assure that you're entering it correctly. Then, if you still aren't able to connect, try manually unplugging the ethernet cable from your PC, then plug the Ethernet cable into the laptop. If you get a signal, skip to the third paragraph, if not then read the next paragraph.
If you aren't getting a physical connection, it could indicate that there is something wrong with some type of software, or operating system settings that aren't allowing you to connect to the internet (leave the network cable plugged in for troubleshooting). Try checking firewall settings (windows firewall is infamous for blocking almost all connections at will). Then, if you're using windows xp, go to the start menu, open the run command, and type "CMD" without quotes (if you're using Vista or Win7, then just type CMD in the search box at the start menu. When the command prompt screen appears, enter this text without quotes "ipconfig /all". If you have an IP address, subnet gateway, and IPv4 configuration, then you're ready for the next step (if not, let me know in a comment, and I'll leave the instructions for that solution). If you're using xp, then right click computer, click properties, go to the hardware tab, then click "Device Manager" (for Vista/Win7, just type Device Manager in the start menu search box). Scroll down (if you have to) to Network, click on it, find your physical network card, right click and uninstall it (don't worry, this won't hurt anything). Wait for a few moments, then right click anywhere in the Device Manager window, then select "scan for new hardware". This will find the NIC you just uninstalled, and reinstall it (with original drivers, unless you've upgraded your Operating System, then you'll have to get the drivers from the manufacturers website via your desktop). Reboot the laptop, and try connecting with the LAN cable again. If this solution doesn't work, leave me a comment describing what you've done, and any error messages that have come up.
If you recieve a signal from the LAN cable, and still cannot connect via the wireless card, then back into device manager we go! For xp users, go to the Start Menu > right click Computer > click Properties > go to the Hardware tab > then click Device Manager. For Vista/Win7 users, open the Start Menu, then type Device Manager. Scroll down and find your wireless card, and if you've tried the solution in the second paragraph, you know what we're gonna do. Right click it, Uninstall the wireless card, wait for a few moments, then right-click anywhere in the Device Manager screen, and select Scan for New Hardware. Reboot the system, and you should be working!
Aug 02, 2011 | Computers & Internet
I recently formated my pc but i've got a question mark in other devices on ETHERNET CONTROLER.. i need help .. the brand of my pc is intel
If you formated ther PC you may well need to reinstal the device drivers too. Check what Ethernet Controller you have and Google it for a driver. Try to get the driver from the company's own ebsite if possible.
May 14, 2011 | Microsoft Windows XP Professional
Vga driver
VGA ==> Video Graphics Adapter
DRIVER ==> device-driver software to allow Windows to use the device
So, what manufacturer of video-card?
What model of video-card?
What Operating System are you using? XP? Vista?
To find the correct device-driver software, the above 3 questions need to be answered.
Have you looked on the "support" web-site for the manufacturer of the hardware?
May 08, 2011 | Computers & Internet
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
its direct 3d driver: you need to reinstall the last version of directx, or perhaps your videocard driver before
Nov 21, 2008 | Microsoft Windows XP Professional With...
EnGenius EUB-362 (EUB362 EXT) Wireless Adapter Logo
278 people viewed this question
Top EnGenius Computers & Internet Experts
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
