Question about Gigabyte GV-NX66128D GeForce 6600, (128 MB) Graphic Card
GF 6600 installation problem
I've upgraded my graphic card to GF 6600, after removing old drivers and installing X 9C. Drver version is 93.71. PSU is 450w. My CPU is AMD athlon 2400+. Now, when I open a vedio file,PC freezes. Please help.
Try to install the detonator softwear for youre graphics card.
Posted on Oct 05, 2007
SOURCE:
How do i find out witch display driver to disable so i can install new video card
You don't need to disable any driver, unplug, use ESD protection, install Graphics Card, move the monitor cable to the new card,(you may have to boot on the old monitor connection and install driver), install the driver for the new card and reboot plug into the new card. Do your windows updates to obtain the latest driver. You can open the Device Manager, open Display adapters and disable the Intel graphics adapter. Is it a PCI or AGP Graphics Card? Remember: with a Aftermarket Graphics Card it requires more Power/Watts, you should consider a PSU upgrade. You didn't post the Make, Model Graphics Card, usually there is a Min. Power Spec. for the card listed on the box.
Apr 10, 2013 | HP Compaq Presario SR1500NX (PX786AA) PC...
I've got an old GF FX5200 128MB DDR TV PCI card. how to install in (both hardware & software-driver)
Hi' Sir '' the video graphic cards and DDR 128 Ram are usually plug and play, just install to any selected slots and if you have the DVI TV OUT installer , when windows starts insert CD installer then follow command and install driver.
Jul 16, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
Unable to chnage resolution higher than 640x480 ( GF PX9600 gt)
I would definitely double check the make and model of the video card and make sure you have the correct driver.
Joe
Mar 23, 2009 | Nvidia GeForce 9600 GT,, PCI Express...
Incomplete graphix on screen and slow computer response
What is the wattage of your PSU? You should have, minimum, a 300W psu installed. that "could" be the problem.
Are you able to get through POST boot? If so, can you load into safe mode? I would completely uninstall the drivers and reinstall again. I assume you're using XP, and with XP, it's always best to remove old vid drivers before installing new. Safe mode is the best place to do this, as it only loads the very basic vid drivers.
If you cannot get to safe mode, pull your card out, blow air in the AGP/PCI slot it uses. You may have some dust down there preventing a good connection.
Pop the card back in, load into safe mode if you can, uninstall/reinstall the drivers. If that is a no go, replace the card. Sometimes you DO get bad cards off the shelf.
Mar 14, 2009 | Computers & Internet
Display driver problem
Go to the website of the manufacturer of the computer or graphics card and download and install the latest driver.
Feb 27, 2009 | Computers & Internet
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Computer freezes during game
first of all you should know that even though pentium 4 isn't that old there are still some problems, for example the d processor uses sd-ram or ddr1 ram which are much slower that ddr2 and ddr3 "ddr1 isn't that slow" but if u're using SD-ram then u might wanna upgrade your rams a bit.
Dec 23, 2007 | Biostar P4M800-M7A Motherboard
Problem with ASUS Geforce 6600, 256MB, AGP8x
Its most likely drivers. Completely uninstall all Geforce drivers and and software. Some video uninstall programs only remove the software and not the drivers. You'll need to go into device manager and uninstall the video drivers from there. Double check to make sure MX440 drivers are gone as well. When you restart and windows wants to install your new card, cancel it, then run the Geforce setup program. That way you won't get conflicts with a windows basic driver. Then make sure you have Directx 9c installed. Directx 10 isn't necessary because I don't believe the 6600 supports it anyway.
Good luck
Oct 24, 2007 | ASUS Extreme N6600 GeForce 6600, Graphic...
Open Questions:
Dell Printer support phone number +1=855=536=5666+ Dell Printer Customer Service QEFKEFU Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
See all Gigabyte GV-NX66128D GeForce 6600, (128 MB) Questions
Gigabyte GV-NX66128D GeForce 6600, (128 MB) Graphic Card Logo
81 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
