Question about Kenmore Elite 45986 Front Load Washer
Washing machine door gasket.
The wife put a one-inch hole into the bottom of our front loader washing machine door seal.(She did find the torn-out piece). Instead of replacing the whole seal(admittedly the best repair!), I'd like to try "glueing" the torn-out piece back into the hole in the door seal!... My question to you is: Which adhesive or gasket seal MIGHT be best for attempting this tempotary repair? I was thinking about using an automotive gasket product, but am not sure about the adhesive quality of these materials in their ability to adhere the door seal material to itself. Any information/suggestions as to what adhesive/gasket material to TRY would be most appreciated! I atleast want to "give it a try" as the washer itself isn't worth a new $80. gasket + the hassle of installation, and the gasket can't be rotated. Thanks! dickmd
  • 209 Answers
Re: Washing machine door gasket.
I am a recently retired appliance engineer of 20 years and seen every bodge job / trick and short cut in the book which people have done to save money its simple DON'T WASTE YOUR TIME its a dam sight easier to do it right the first time
Posted on Oct 04, 2007
0 characters
3 Points
Water dripping out of front door at the bottom during washing
Check for a torn or distorted seal or gasket on the door
Apr 23, 2012 | Kenmore HE2 Plus Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Jun 14, 2010 | GE WSXH208A Front Load Washer
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I have a GE front loader that leaks from the bottom, any ideas what it is from?
Is it coming from the front? You can take the bottom panel off and look inside. If the middle is not wet, it may be from a torn door gasket. Pull back the rubber seal on the machine (not the door) and you may see a big tear. That's what happened to ours. We ordered a new one on ebay and we are installing it now.
Apr 11, 2009 | GE WSXH208A Front Load Washer
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Kenmore Elite 45986 Front Load Washer Logo
895 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
