Question about Dell Inspiron 1525 Laptop
Driver acpi pnp0303
I need windows 7 driver for dell inspiron 1525 keyboard
SOURCE:
SOURCE: Xp Drivers for Dell Inspiron Laptop 1525
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&SystemID=INS_PNT_PM_1525&os=WLH&osl=en
Nominally you might get a more accurate answer by going to support.dell.com and entering the 'service tag' number (on the bottom of your machine next to the 'express service code'.
This machine also includes a field in the BIOS setup program; hit the F2 key when you see the Dell logo to start the BIOS setup program.
Posted on Dec 25, 2008
ginko
  • 19396 Answers
SOURCE: dell 1525 inspiron driver
Here is general download page for your laptop, from Dell.
Here also few direct links:
Dell 1525 XP audio driver.
Dell 1525 XP modem driver.
Intel chipset
Ricoh chipset system driver.
Posted on Mar 16, 2009
ikechinedu
  • 184 Answers
SOURCE: I need to install a keyboard for a Dell Inspiron
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Posted on Apr 17, 2009
anujpaul
  • 217 Answers
SOURCE: Inspiron 1525 Webcam driver error
go to techbuddies.org.. guaranteed solution to your problem... they will surely help you out in minutes..
Posted on Jul 10, 2009
sunnylab85
  • 302 Answers
SOURCE: Dell Inspiron 1525 on board mic not working in win 7
download the driver from the maunfacturer site it will work when it is installed
Posted on Oct 13, 2009
I have dell inspiron 1525 once i attached wofer with my laptop and suddenly affter that my audio device stop working i nstalled windows 7 after that but now high defination audio device is not plugged in...
you will need to re install the drivers for the high deff audi device from dells website that should solve your issue i had the same issue with my toshiba when i upgraded to 7
Apr 19, 2011 | Dell Inspiron 1525 Notebook
Windows 7 drivers dell 1525 i want. how to get.?
go to dell support and drivers, all your drivers will be available on the dell drivers download. just go to dell.com
Dec 28, 2009 | Dell Inspiron 1525 Laptop
Keyboard works during boot up, but not afterwards.
reinstall the driver or in start open control panel click keyboard and use the trouble shooter
Oct 23, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Oct 13, 2009 | Dell Inspiron 1525 Notebook
After doing a repair on windows xp, keyboard is
You may have to get the disc or something to re - install your keyboard, maybe when you repaired your laptop it didn't recognize your keyboard.
Reply back if you have anymore problems.
Thanks.
Jul 18, 2009 | Dell Inspiron 1525 Notebook
I want dell inspiron 1525 drivers for windows xp
You'll find the XP drivers you need here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
Mar 20, 2009 | Dell Inspiron 1525 Notebook
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Logo
74 people viewed this question
Clive
Clive
Alun Cox
