Question about Microsoft Office Standard for PC
EXCEL FILE OPEN TAKE MORE TIMES
WHEN A WORKSHEET ONLY ONE SHEET AND IT CONTINUE WORK AFTER CLOSE FILE AND REOPEN THAT FILE TAKE MORE TIMES FOR OPEN SPREDSHEET, SO PLEASE GIVE ME SOLUTION HOW OPEN QUICKLY. REGARDS, RANJAN
  • 82 Answers
Upgrade the software
Posted on Oct 09, 2007
SOURCE:
Excel sheet has been lost how to recover
Lost Excel file can be recovered from:
  1. Recycle Bin - If you have deleted the file with normal delete.
  2. Backup - If have maintained the backup of file.
  3. Email - It may possible that you have mailed the file to someone.
  4. 3rd Party Recovery Software - Recuva, Stellar Data Recovery ...
Oct 29, 2012 | Microsoft Office Excel (License Only)...
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
Excel work sheets delete,pls how is it restore
Easiest way would be to use the Undo function to work your way back to the point prior to deleting the worksheets. If you can't back up through the list that far, you could close the file WITHOUT SAVING IT, then reopen the original file again. If you have already saved the document after deleting the worksheets, you will have to restore it from a backup (you do perform backups, right?) and continue working fro there.
Apr 15, 2009 | Microsoft Computers & Internet
Closing Worksheet on executing Hyperlink command
You could do this by creating a close button with the worksheet- Do this via insertin ga prompt in Macro.
Dec 20, 2008 | Microsoft Computers & Internet
Can't reopen circular reference file in excel
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
Nov 05, 2008 | Microsoft Excel for PC
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
PASSWORD RECOVERY
Try to Recover Excel Password with Excel Password Recovery 5.0. I have searched MS Excel Password Recovery, found this efficient Excel Password Recovery program. It supports all versions through 97 to 2007.
Remark:
Office Password Recovery tool also can help! It recovers Password to Open and removes both the Password to Open and Password to Modify for Microsoft Word, Excel, Access and PowerPoint of versions through 97 to 2007.
Feb 18, 2008 | PC Chips M825G Motherboard
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Hi friends
Have all worksheets open including the one that is to be the tally sheet.
On the tally sheet, select a cell that you want to link to one of the other sheets and press the equals signto begin the cell formula. Without pressing the enter key, click on the cell in the other worksheet that you want to show up in your tally sheet.
Press enter to complete. This will link that cell in the two worksheets together as long as the spreadsheets remain stored in the same places.
Dec 24, 2007 | Microsoft Excel for PC
Microsoft Office Standard for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
