Question about SMC Barricade g SMC2804WBR Wireless Router
Router unable to connect to internet
Hi, I've been trying to get my router working again. I've updated the NIC drivers, the router firmware, changed cables- nothing seems to work. It works when I bypass the router and connect straight to the modem. I'm suspecting that there may be an issue with the router's ports. Here's a dump on ipconfig- IP Address: 192.168.0.2 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.0.254 DHCP Server: 192.168.0.1 Lease Obtained: 04-Oct-07 3:06:07 PM Lease Expires: 04-Oct-07 3:06:17 PM DNS Servers: 202.154.83.53, 218.217.227.3 WINS Server: This all happend when I attempted to install a Linksys VoIP ATA. I may have connected the cables incorrectly and could've fried the router. Help! Thanks, Joe
  • tunee1234 Apr 23, 2008
    yeah, exactly same problem, perhaps router is dead..
  • 49 Answers
Are the info coming from PC connected to modem?
If you are connected to Router and pulled up that Data, you might just need a power cycle. Turn off everything from PC to router - to Modem and Power on everything starting off with the modem this time. After power cycle, check if getting the same data. If yes, then type "ping yahoo.com" if you have four replies then you must be able to go online, if not then disable firewall (norton, maccafee etc)
Posted on Oct 15, 2007
SOURCE:
NV55C Gateway Lap Top cannot connect to wireless router
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Jan 23, 2012 | Gateway NV55C03u Laptop
Router ZyXEL HW -D1, Laptop win 7. After several days of good wireless connection PC losing connection. It discovers routers but unable to connect. Trying to restart router, to change security settings...
1. this issue may be due to the age of the router and also firmware updates need as it reads
2. check the manufacturers site for update instruction set
3.Here are some step to try to see if the router is indeed grandfathered:
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Apr 22, 2011 | Zyxel P660HW-D1 Router
Internet going off VERY frequently
1. Firmware update may be required for the Router.
2. check your firewall settings and the Wireless configuration in the router.
3. You may have to allow the MAC address for the device that you are trying to connect with to have permission to connect to the network.
4. Verify IP for the the PC ( this is done in the DOS window) at the DOS prompt type "ipconfig /all" this will bring up the network report as to what is and what is not connected.
5. Unplug router and modem from the AC.
6. Reboot the PC.
7. Window is totally different from the router firmware updates.
Windows is downloading it security and web update when you see the prompt. This has nothing to do with the router.
Jun 18, 2010 | 2wire (1000-400108-001) Router
Belkin N+ keeps dis-connecting from internet
u can try dowloading the latest firmware for the n1vision router...
here is the link.... http://en-us-support.belkin.com/app/answers/detail/a_id/503/p/328
download appropriate version and save in the hard disk.... login to router page... type 192.168.2.1 in internet explorer... password leave it blank and click submit.... click update firmware on the left....select browse and update the firmware dowloaded... after updating, login to the router page again and click on restore factory defaults(must)....your problem ll be rectified....
Feb 24, 2010 | Belkin N1 Vision Router
My internet keeps cutting out nad then connecting
How are you connecting? Thru a wireless router at home?
You may need to upgrade the firmware on the router or just change it to a different channel. You will need to get into the routers control panel to do this.
Mar 18, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the [email protected] format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router gets disconnected
If you know how to open the setup page of the router, look for MTU. Normally it is set to Auto with default size of 1500. Now set it to manual and change the value to 1463 and save the changes. Power cycle the router by unplugging the power for 30 seconds then plug it back in. Observe your connection if it keeps on dropping.
Another is you need to isolate the problem if its the router or the modem. Try to connect your PC directly to your modem and observe if it does the same thing. If it does the same problem, call your Internet Provider to fix the modem.
If the problem still persist on the router after changing the MTU, try to update the Firmware of the router and hard reset it by pressing the reset button for 15 seconds then power cycle it.
Jul 24, 2008 | U.S. Robotics (USR8200USR8800KIT)
Disconnection problems
I see. You can try changing the wireless settings of the router. You can do that by accessing the web based utility of the router. Here are the instructions:
1. Click the Start button, and then click Run.
2. Type the following text in the Open box: http://my.router
3. If this is the first time configuring your Dell Wireless 2350 Broadband Router, or if the user name and password have not been changed from the default settings, type admin in the User Name field and admin in the Password field.
4. Click the OK button. The Configuration screen appears.
5. Under the Basic settings, under Wireless Settings change the channel from Auto to 1, 6, or 11.
If that does not work, you can try updating the firmware of the router. You can download the firmware from this site:
http://www.dell-drivers.com/dell-drivers-downloads/Dell-Wireless-2350-Broadband-Router_8689.shtml
Here are the instructions on how to upgrade:
1. Reaccess the configuration page of the router using a wired computer.
2. Click on System Tools, find Firmware Upgrade.
3. Click Browse and search for the firmware you downloaded from the site I gave you earlier. Select it and then start the upgrade. Let the firmware finish its upgrade.
May 21, 2008 | Dell Wireless 2350 Router
Unable to reach some websitres
Try updating the firmware of the router. Go to http://networking.belkin.com Make sure you download both the firmware program and the instructions. Follow the instructions for updating the firmware.
Feb 16, 2006 | Belkin (F5D5230-4) Router
Open Questions:
SMC Barricade g SMC2804WBR Wireless Router Logo
135 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
