Question about Whirlpool GS6NBEXR Side by Side Refrigerator
GE side by side
Recently acquired older fridge. Cleaned it well with hose, soap, etc. Now, freezer is working overtime, but fridge does not seem to be cooling as well.
  • 473 Answers
Check to see if there is air flow coming from vent/damper into the fridge section. Also you should hear a fan running in the freezer. If the fan is running and no air flow then the problem is in the damper/vent. If the fan isn't running then it may be bad. Check to see if you have power to the fan motor if it is not running. Note: Fan will not run if unit is cycled off or in defrost which is normal.
Posted on Oct 06, 2007
SOURCE:
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
