I am converting my vinyl and cassette music collection to mp3 as follows: * Burn song to CD * Convert CDA to MP3 using Express Pro * Edit (if necessary) file using WavePad. Files sound fine when played through Real Player or Windows Media Player, but tinny and hissy on Itunes. I have tried different equalizer settings which help, but still do not rival the other players. (The same holds true for files converted to mp3 from store bought music CDs.) Is there another setting or feature that can correct this in Itunes? Is there perhaps another media player instead of the Ipod that would use Real Player or Windows Media Player? Thanks for the assistance.
How to convert m4p music to
mp3
Convert m4p to mp3,itunes to windows media,
convert itunes music
The M4P file type is primarily associated
with 'Protected AAC File' by Apple Inc. AAC is the audio layer from the
follow-on format to MP3. The .M4P extension is AAC purchased from Apple's Music
Store (iTune) and is protected by a Digital Rights Management scheme.
Most songs sold through the iTunes Store
are encoded using FairPlay-encrypted 128 kbits/s AAC streams in an MP4 wrapper,
using M4P extension. Apple has maintained tight control of its FairPlay
encryption. Other online music stores cannot sell music files encoded with
FairPlay. This means that consumers who want to listen to songs downloaded from
the iTunes Store must either have an iPod or convert the files to an open
format. There are two ways to convert M4P music to MP3. One way is to use itunes
for sophisticated computer user, another way is to use third party program for beginner,
which is much easier.
Part
one: Using itunes to converting M4p music
Step
1: Run iTunes and set burner options firstly. You
can choose
Edit>Preferences>Advanced>Burning
menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner
program, NoteBurner.
After you install it, you can choose NoteBurner Virtual CD-RW as what you do in
the first step.
Step
2: Create a new playlist in iTunes and add all m4p
files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in
NoteBurner. After you click Settings button, you can set the output as MP3, WAV
and WMA.
Step
3: Click Burn Disc button in iTunes to starting the
burning. If you use NoteBurner, this is the final step since the program can
rip back the burned music automatically. The output folder will be open
automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music
back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click
small Importing tab inside the Advanced tab to choose "WAV encoder"
or "AIFF Encoder" in the "Import Using" dropdown. In the
left-hand panel under "Devices", select the CD that you burned
Step
4: In the main window opposite, deselect any CD
track(s) you do not want to convert. Right-click or control-click over them,
and choose the "convert to AIFF" or "convert to WAV"
option.
Step
5: After the conversion, you may find the converted
file at C:\Documents and Settings\Administrator\My Documents\My
Music\iTunes\iTunes Music
Part
two: Using third party program to convert M4p music
Comparing to the previous method, the
following is more simple and easier, you can finish the job with just several
clicks.
Step
1: Free download M4P
Converter, install and run it.
Step
2: Clicking "Add" or directly drag-drop protected
M4P files. Batch M4P to MP3 conversion supported.
Step
3: In the "Setting" button, choose MP3
format (*.mp3), you can also custom the music.
Step
4: Click the "Start" button to start converting M4P
to MP3. After successful converting M4P to MP3, the result shall be stored on
the "Output path" folder. Then you can use them for playing without
any limitation.
