Question about Jenn-Air JCD2290HES Side by Side Refrigerator
Freezer/Fridge work SOMETIMES
For the past week I have noticed that my freezer is not working properly. First I woke up to find water all over the floor from where the ice had melted......I thought the door had been left open overnight so I chalked it off to that. I poured out the melted ice and shut the door. It worked fine for a day or so then it happened again. This time my food was completely thawed out but still cool. The fridge side was fine. We set the temp control on the freezer side up a notch and it started working again....for a day or so......now the fridge and the freezer work and then don't work - get cold and then not so cold...... the compressor keeps kicking on and off and is becoming more and more frequent.....every 3 or 4 minutes as of today and only runs for a couple of seconds and then shuts off... sounds louder than normal. HELP!
  • usmcsandy Oct 15, 2008
    I have the same problem. I lost all my food a few weeks ago, then it started working again, same thing last friday but I didn't have much food because of last time, then this morning the same thing but it is still not working I called and a repairman is coming out Friday!
Guys, I need advice and any help will be appreciated.
I have Jenn Air model JCD229Key. I think it has restricted/plugged
system. I have troubleshooted it so far that I know 100% that
compressor, thermostat and fans are working fine. I need your help to
figure out where is the system plugged. When i fire it up it, compressor
starts buzzing and working normally. There are two pipes that lead from
the compressor to evaporator (one is thicker and another one is thin
like toothpick) These two pipes start freezing(frosting) immediately but
the thicker pipe starts to defrost, and first two evaporator
lines/circles (look like coil)- they are frosted/frozen too. So you can
wipe off the frost with finger but hey freeze immediately - but nothing
above that gets frozen. THANKS
Posted on Dec 10, 2007
  • 473 Answers
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
Posted on Oct 05, 2007
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Fan in freezer has stopped working,have defrosted and fridge seems to be cooler.
Simply defrosting the freezer might solve your problem. Sometimes ice can form on the fan or fan motor, and of course, prevents the fan from turning.
If there is ice here, your refrigerator isn't defrosting properly. This sounds like a defrost problem that may need a part replaced. Check out this site for details and photos. Refrigerator Defrost Parts
May 07, 2014 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Kitchenaid Superba freezer side cuts out sometimes
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Fridge/freezer
Denis, frosting back to the compressor is usually a sign of refrigerant overcharge. The fact that you noticed one of the other lines opened could indicate a wrong charge. You will need a cfc certified tech to check this thing out. This way he can check for a proper charge, restriction or a weak pumper...Catriver..post back.
Sep 04, 2006 | Smeg FAB310X Top Freezer Refrigerator
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
262 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
