Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Whirlpool d/w gu2400xtps1,clean light flashing
2 Suggested Answers
SOURCE:
rickead1
  • 1998 Answers
SOURCE: My whirlpool dishwasher has a
How many times is the green light flashing on the unit? Or is it just flashing over and over continuosly and not stopping. The number of times the light flashes usually represents an error code with the unit. Also try pushing sani rinse - dry button and then sani rinse - dry button then you should see the control panel light up after that hold cancel for 5 seconds message me back if this does not work. Also have you tryed shutting the unit off for 7 minutes at your breaker box sometimes this allows for the control to reset when this is done I await your reply To how this works with eliminating the blinking normal light Thanks again Rick
Posted on Jun 14, 2011
Clean light is flashing 7 times, stops and flashes again. Can't make it started anymore.
my whirlpool is doing the same thing. I'm trying to find a wiring diagram with not much luck. A work around I use is to turn the breaker on the fuse box off for 5 seconds then back on. The dishwasher then works for one cycle.
Aug 09, 2015 | Whirlpool Dishwashers
Flashing clean and heat light?
Sounds like you might have lint build up. Clean out lint trap and remove the back and clean out all lint. The lint build up could be causing a over heating problem. And this is a fire hazard.
Aug 08, 2015 | Whirlpool Dishwashers
Flashing orange fault flashes four times whirlpool
4 flashes on whirlpool diswasher usual means a draining problem clean out your filters
Feb 02, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool awz3518 'Clean Filter' light is flashing
It would appear that this issue is related to a cold location, or the arctic air coming in through the vent hose.Sort of defeats the purpose of a dryer not working when its cold.
Dec 23, 2009 | Whirlpool Dryers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
75 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
