Question about Gateway M675 Laptop
Gateway M675 PRR Windows XP 3.0 GHz
I downloaded and flashed the bios with the latest from Gateways support know I have no LCD if I attach an external monitor I do get something but its not very readable like several over lapping views anybody have any sug. other than tossing the notebook???? Clint
  • Anonymous Nov 05, 2007
    Go with external monitor ... open the winplash download the bios on
    http://support.gateway.com/support/drive...
    and backit to original !!
    remember , open winplash - advanced , set all options correct !
    Bye
  • dennyleofe Jun 13, 2008
    how can i load bios on my laptop....everything is new....new motherboard and hard drive on m675 gateway laptop...repair man says need the old hard drive....dont have it....what do i do now???
    Guru:
  • 120 Answers
Well, you can purchase a replacement bios chip online. Depending on your technical skills that option may be over your head, but there are companies online that will do it for you if you mail it to them. You could also purchase the chip and bring it to a local shop, though not all shops will have a technician that can do this for you. You could also see if you can send it to gateway for reflashing, it will probably be costly but may help you.
Posted on Oct 04, 2007
After using my Gateway M 675 prr and now it is not working. The screen is black, the fans are working and the lights are on, just have a black. What can I di?
The Gateway 675 are known for video card problems.You can unseat the card and clean it,then replace the thermal grease.The thermal grease on these get runny under heat and causes the video card to loose contact.Try the grease if that doesn't work the video card will need to be replaced.
Jun 25, 2011 | Gateway M675 Laptop
Cannot find the Lan drivers for the Gateway M675 S/N# 3501765. Gateways site does not have these drivers.
Hi tdogg...
Gateway M675 3501765 Lan drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Jan 21, 2011 | Gateway M675 Laptop
My Gateway M675 notebook begins to boot and 4-5 minutes into whatever is loading it freezes and will not allow me to do anything at all. To shut down I need to press the reset or remove the battery. Any...
OVERHEATING ~ me thinks ~ especially at the CPU where most heat is generated!
SEE this YOUTUBE to learn how to get the BOTTOM off... Take your Gateway to a tire shop and blow it out thoroughly!
Bring a MASK and a SOFT / OLD paint brush and round toothpick to assist.
Pay SPECIAL attention to the FAN area AND the DUST UNDER it!
SEE the PHOTO below AND NOTE the DUST UNDER the fan! Many times that fan gets IMPACTED with dust and dirt! So again ~ clean thoroughly!
Anthony
Gateway AIO ZX4250 Teardown 1 3
Dec 08, 2017 | Gateway M675 Notebook
Install windows xp media,buttons don't work on gateway m275 tablet pc.
the link below should download the button drivers for windows xp on your laptop. if you like you can navigate through gateways support section and find all of the drivers that you need.
http://support.gateway.com/support/drivers/getFile.asp?id=19587&dscr=Gateway%20M275%20Button%20driver,%20version%205.01.2600.2156&uid=254270972
Dec 17, 2009 | Gateway M275 Tablet PC
My Gateway M675 laptop doesn't allow me to display video on an NEC np61 projector...I connected the cables before turning the PC back on and I see the Windows screen, but not the video...
Here is a direct link to the user's manual of the M675:
http://support.gateway.com/s/Manuals/Mobile/9528976.pdf
On page 65 of this manual, there is a detailed description of how to get this laptop to work with projectors.
Nov 06, 2009 | Gateway M675 LAPTOP LCD HINGE/CLUTCH (L+R)...
I flashed the bios on my gateway m675 and it stopped working. It turns on but screen is blank. If I hook it up to an external monitor I can get into bios. Is there anyway to get it back to the way it was?...
pls check the bios set up externally if you mistakenly turn the brightness down, and correct it
or see if ther is any brightness button you accidentally pushed on the top of your laptop
or ther could be some problem with your LCD inverter or the LCD itself.
Aug 08, 2008 | Gateway M675 Notebook
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
M675 BIOS CHANGE
THE BIOS IS CORRUPT
MOTHERBOARD NEEDS TO BE REPLACED (300-1000USD) OR BIOS CHIP NEEDS TO BE REPROGRAMMED BY A PROFESSIONAL
Apr 15, 2008 | Gateway M675 Laptop
Gateway M675 creen problem
Yes you are correct and they are beggars to fix.  Your problem is fixable just ask these chappies:
http://lcdrepair.net
Oct 10, 2007 | Gateway M675 Laptop
Gateway M675 Laptop Logo
969 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
