Question about Rowenta Professional DE880 Iron
Stuck steam button
I dropped my iron and now the steam button is stuck down. How do I get inside to look at it?
SOURCE:
snakehead
  • 1074 Answers
SOURCE: Shot of Steam
take it down and clean, it is clogged up.good luck.
Posted on Apr 18, 2007
snakehead
  • 1074 Answers
SOURCE: I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
  • 24 Answers
SOURCE: Rowenta iron
Dropping any iron is the kiss of death... dont use it again, especially on the steam setting.. you could electrocute yourself..
Dispose of it safely and get a new one. You wont make that mistake again in a hurry... I didnt!
:o)
Posted on Aug 03, 2008
DiYerTech
  • 70 Answers
SOURCE: DG-980 Iron: The button to use the steam is stuck. I was ironin...
Hi Mary, sounds like something jammed in the trigger mechanism or the microswitch button is stuck in the housing. Unplug the iron, let it cool. Gently pry up the blue cushion from the handle from the front towards the rear cord, you will see the trigger, the actuator tab and the microswitch button (nib) that should be sticking out, if it is flush with the housing it is jammed down. That switch is replaceable, but I don't know how savy you or your appliance servicer are at replacing it. Here is where I get my parts:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Please keep us informed as to your progress resolving this...
Posted on Jun 06, 2010
How long do you have to descale button down for on a supreme steam ultra steam iron
Perhaps the manual has that information.?
supreme steam ultra steam iron manual Google Search
I like the traditional way :>)
Tip & How-To about Irons
Cleaning a Laundry Iron Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it. When it has cooled a little, sit it faceplate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the soleplate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
Posted by Andrew... on Mar 18, 2016
Cleaning Laundry Iron
Mar 07, 2018 | Irons
Tip
How to release the stuck steam button in Shark iron-61468-10?
If the steam button is got stuck in the down position in your iron then follow this procedures to release the stuck button:--
1) First of all pull the button up. You may have to coax it up; you can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only).
2) Below the button is a stem that operates the valve, gently pull it back up with a pair of needle nose pliers (careful - the stem is made up of plastic material).
3) Then replace the button (align the stem into the hole on the bottom of the button to its exact position. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :)
It seems like it sticks when the iron is left unused condition for a period of time; as if the valve gets stuck up when dry. leave water in it this time, although the instruction manual says not to. But leaving the water in it may not let it get dry.
This will help.good luck.
on Feb 28, 2010 | Irons
Tip
Disassemble?
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on May 08, 2009 | Sunbeam 4214 Iron
Rowenta iron dg3050 iron potion broken and will not hold steam can you replace the iron part
More than likely your steam valve is broken or stuck. I had one of these and they are worth having repaired. Google Rowenta Repair Center.
Jun 15, 2014 | Rowenta DG5030 Iron
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Steam button stuck
put some vinegar in your iron and swash it around. It will remove the calcium or lime that is making your button stuck. Be sure to run a lot of water through the iron after or your clothes will stink.
Apr 24, 2013 | Black & Decker Irons
May 18, 2010 | Rowenta DG-980 Iron
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Rowenta Professional DE880 Iron Logo
76 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
