Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Zanussi DA6142 dishwasher only works whe...
By miss_dena on May 01, 2009
As long as the door is open enough to prevent the catch from clicking (in the closed position) it works OK, but if I push it the final milimetre and the catch clicks closed then it won't work.
I can use it - carefully - by closing the door enough to prevent leakage but not enough for the catch to click... is this a diy repair (in which case, what is the name of the spare part that I need) or will I need to call someone out...?
The machine is a few years old.
Very many thanks,
Dena
Solution #1
posted on May 01, 2009
Not Rated)
restorerjohn
Rank: Apprentice
Rating: 100%, 1 votes
It is unlikely to be very difficult, however the door front panel and control panel will most likely need to be removed. Usually there are several screws across the top inside door edge and down the left and rigtht side of the door towards the hinges. They are often tamperproof torx or hex, sometime philips, so ensure you have the right driver. Also ensure the POWER IS OFF. UNPLUG the power lead and put it next to you- be 100% sure it is unplugged before you do anything. I cannot stress this enough, if the machine is hardwired into the power- LEAVE IT ALONE and call a repairman. The door switch needs adjustment or perhaps a part of the latch mechanism has broken. Sometimes the actual microswitch can become detached (plastic spigots break off) and it gets in a place where the door tongue turns it off when it should be on. Once the front panel is off, you can open and close the door a watch the mechanism to see where the problem is.
But if in any doubt, get a service manual for the machine, study it and diagnose the problem BEFORE delving into the machine.
Be careful, the edges of the door panels are quite sharp and once the panels are off, the main door can spring up due to having less weight on it.
John
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
I have a Bauknecht dishwasher Model: GCX 5521. It beeps a few times when switched on but it seems to... (More)
Answer
None of the buttons will work on the front of our dishwasher.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
