Question about Intel Motherboard
Invalid boot.ini I have xp-sp2.During booting,a message occurs on the screen-"INVALID BOOT.INI BOOTING FROM C:" Then the systems boots.although there is no problem thenafter.
<3 you guys.
Posted on Jul 19, 2008
    Guru:
  • 120 Answers
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Posted on Oct 04, 2007
When i start my conputer invalid boot.ini to C:/ducument apear before open.
When you start your computer it says invalid boot.ini and then freezes there? Or, your system is booting into windows; and your receiving another error ?
Sep 02, 2010 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
Dec 28, 2008 | Microsoft Windows XP Professional for PC
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
Hp pavilion zd7000
Insert your Windows DVD and boot from that choosing 'repair'.
Jun 11, 2017 | HP Computers & Internet
Booting error
What I would do is take the hard drive (1) out of that machine and put into an another pc - xp would be fine. Now go to the root of harddrive (1) and edit the boot.ini file. you will see an entry similar to this ......
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
All you need to do is make sure you know which disk you're using (c drive is 0 usually) and the partition should be set to 1 for regular installations.
Did you add any drives lately? or make any changes to your OS?
Jun 14, 2008 | Microsoft Windows Server Standard 2003 for...
When i start my computer a problem occurs that searching for boot record de-o..ok and then hangs
use the windows cd to perform a repair installation if you get startup errors or the system wont start.
May 28, 2008 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
207 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
