Question about LG RU-52SZ30 52" Rear Projection Television
LG Rear pro RT-52SZ30RB
The unit will operate fine when you turn it on then about 45 secs later it turns itself off. If I turn it on again the same thing happens, goes on for 45 secs then turns off. The picture is fine when it is running. Look forward to any help you can offer.
  • Anonymous Feb 10, 2008
    Turn the TV on and shuts dwn after approximately 1 minute. Red light flashes on "Lamp Indicator" on the front of the unit. ANy sugeestions? I habe been told a new bulb may be in my future? Anyone know how much and where?
  • Anonymous Apr 28, 2008
    My TV turns on and then will stay on for some time.  Then it will turn of for about 30 seconds and then turn back on.
My TV was doing the same thing. Turning off after ~20-30 seconds. I replaced the bulb and had no more problems. It is made to be replaced fairly easily from a panel in the back with a phillips screwdriver. The lamp is available on-line for about $170 plus delivery (less than $200 for next day delivery). I paid a guy $100 bucks to come out and tell me that. He did give me the part number to order (which did not coincide with any markings on the bulb that was in place. For my model RU-52SZ30 it was a replacemnt bulb type 6912V00006C.
Posted on Nov 08, 2008
My unit will operate for about 30 seconds and it will shut down by itself, can you help me sove this problem.
Thanks.
Posted on Oct 09, 2008
    Problem Solver:
  • 13 Answers
I have this kind of tv model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Posted on Feb 07, 2008
When did you replace the lamp last time?
When was TV purchased?
Please reply to lampsale@tpg.com.au
Posted on Jan 02, 2008
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
RT 52SZ30
I have a 52" LG Prjection TV model number RU52SZ30 and it turns off after 45 seconds, also the blinking lights flickers on the lamp. What should I do first replace the lamp or reset the tv and how can I reset my TV. If a lamp problem where can I purchase one and how much and if I buy a lamp and I still have the same problem what do I do now.
Thanks.
Sep 03, 2008 | LG RU-52SZ30 52" Rear Projection...
LG RU-52SZ30 52" Rear Projection Television Logo
307 people viewed this question
Steve Allison
Steve Allison
