For Universal Remote Control brands listed below, please use accompanying codes and refer to your Universal Remote Control UserManual for basic Instruction for changing TV code to operate the TV model. Codes for DIRECTV: 0178, 10178 Codes for Time Warner Cable: 0178, 10178 Codes for Cox Communications: 0178 Codes for Comcast: 10178 Codes for Dish Network: 627 Codes for Fios Verizon: 0205, 0057, 0493, 0775
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
