Question about ASUS P5RD1-VM Motherboard
Memory Issue I am using (CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory Model TWINX2048-3200C2PT) with this motherboard. Is there anyway to make the memory compatible with my motherboard. Since I am receiving more and more errors as i keep using it... Thanks so much...
  • freeforme Oct 04, 2007
    Thanks so much for your help.
    Here are the settings under my Chipset - NorthBridge:
    DRam 1T/2T Command [2T]
    Configure DRRAM Timing by SPD [ENABLE]<-- am I changing this one to Disable?
    DRam CAS Select 3.0 clock <--then change this to 3.5 clock? (3.5 seems big to me...)
    DRam tRP Select 3.0 clock
    DRam tRCD Select 3.0 clock
    DRam tRAS Select 8.0 clock
    Refresh rate select [7.8us]
    Does those data seem right to you?
    again, thanks
    Guru:
  • 120 Answers
You could try lowering the Cas latency. Just boot into the bios and try lowering the cas latency up by .5 For example, if it's running at 2.0 change it to 2.5 or 2.5 to 3.0 Yes this will slow down your system, but it may be a more stable speed for the ram to run at. You could also have bad ram, or maybe your problem isn't ram related at all. It's possible your motherboard is the cause of all of your problems. Peter
Posted on Oct 04, 2007
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
What kind of RAM ( ie DDR , DDR1, DDR2 )is supported by d856gsa ;
Intel D865GSA has two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets It Support for DDR-I 400, DDR 333, and DDR 266, Support for up to 2GB of system memory max CreativeTECH
Jan 05, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
PC3200 (DDR400) DDR SDRAM
Maximum 2GB
Jan 03, 2011 | Biostar P4M80-M4 Motherboard
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
I need more memory on my hp m7248n media center pc, what product should I buy and what is the maximum memory I can get on my computer?
This is from HP.
  • Four 184-pin DDR DIMM sockets
  • Supports dual channel, eight memory banks DDR 333/400 DDR DIMMs
  • Supports 2.5v DDR SDRAM DIMMs
  • Maximum HP/Compaq approved memory is 4 GB* without ECC
4 Sticks of PC3200 400 Mhz is max.
Jan 19, 2008 | Computers & Internet
ASUS P5RD1-VM Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
