Question about Nikon Coolpix S50 Digital Camera
Blank screen When I turn the camera on the screen is black..the green power light is on, but after a few seconds it shuts off. The camera is new and worked fine at first. We did the trouble shooting in the users manual but it didn't solve our problem. The battries are new and both at full charge.
  • kris_1 Nov 27, 2007
    i charged the camera and the battery, and when i turn it on it works for a couple seconds then shuts off, even though it says full battery. i plug it into the charger and it works fine until i take it off and it automaticly goes blank. it worked fine up until a couple weeks ago.
    Scholar:
  • 32 Answers
The build of S50 is similar to S6, especially the lens. I fixed my S6.
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen.
Read the following steps once and make sure you understand before action.
(1) Load your camera with a freshly charged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
Want to read successful stories, click this link.
Good Luck!!
Posted on Oct 22, 2007
Can't take picture or record video?
Try turning the screen all the way around and close the screen so the screen its left outside where you can see if that doesn't work you will need to replace the ribon that connects the screen to camcorder.
Jan 30, 2014 | DXG Technology DXG-506V DV Digital...
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Jan 21, 2013 | Kodak EasyShare Z650 Digital Camera
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Nikon Coolpix S50 Digital Camera Logo
70 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
