Question about Samsung SGH-D900 Cellular Phone
Cannot get PC Studio 3 to work properly
Hi there: I can get my SGH-G600 to show that it is connected to my PC via USB cable suppplied with phone, but when I try to run any of the programs in the PC Studio suite it says that it cannot connect because it is busy with another operation under a different program in the PC Studio suite.. BUT, looking at task manager, no other programs are running! Help please... I cannot transfer all my Phonebook to my phone until I get this sorted. Many thanks!
  • 24 more comments
  • Zimbo38 Oct 04, 2007
    what I am saying is that the phone shows that it is connected, but it is not responding to commands from the PC via PC Studio 3
    An Error message comes up saying "Another PC Studio program is performing a time-consuming operation. Retry after this operation is finished". But there is no other operation running... help please anyone?
  • bluecatdevil Nov 23, 2007
    I have the same problem but my phone is an australian SGH-A701 I tried the code but it didn't work on my phone. Any suggestions?
  • Anonymous Dec 15, 2007
    exactly same problem
  • robo100 Mar 09, 2008
    when try to retreive my photos from phone. keeps saying a time consuming operation is in operation. my phone is a sam g600 can anyone assist. i have even completly uninstalled the programme and reinstalled again,only to get same prob.
  • moinul Mar 13, 2008
  • jonnocash Mar 28, 2008
    another pc stucio is performing a time consuming operation
  • Anonymous Apr 08, 2008
    cant get pc studio to work
  • crath Apr 12, 2008
    Same problem as above - stating synchronisation failed - try again later
  • Anonymous Apr 23, 2008
    I have exactly the same problem but with my G600
  • cijo_dj May 04, 2008
    I typed *#52828378# into my samsung sgh-j210 phone this comes up
    1 Trace setting
    2 OTA type setting
    3 Serial test
    4 TFS reset
    I select 3 serial test and the same above menu comes again and again.
    please help. I've bought a latest SGH-J210 handset.
  • Anonymous Jun 07, 2008
    mine is exactly the same & i just braught it today
  • Anonymous Jun 18, 2008
    the same problem
  • Anonymous Jun 23, 2008
    Hi I have a similar problem, I installed the PC Studio Ver. 3.1.2 GG4 disk that came with my phone a G600, I installed the program and it look fine, except I cannot connect to my phone via the usb cable. The Cable and everything were checked on another pc and is in working order, I use Windows XP spack3 any suggestions?
  • maninarayana Aug 01, 2008
    I am having the same problem that when i connect my mobile Samsung SGH j210 to my pc it says "Another PC Studio program is performing a time-consuming operation. Retry after this operation is finished" But no other Operations are there Please help me
  • Anonymous Aug 03, 2008
    The fix doesn't work for me.
    Once I type *#52828378# into phone this comes up
    1 Trace setting
    2 OTA type setting
    3 Serial test
    4 TFS reset
    kindly help -- i'm still stuck with the same issue in pc studio suite. I've the latest SGH-J210 handset.
  • Anonymous Aug 09, 2008
    well i m havin d same prob... nt able to connect to pc...hey any body can tell is there any way dat i can zoom d pics on my phone....
  • Anonymous Aug 20, 2008
    another way is type *#52828378# , then go to trace setting, 2 system trace -select all,go back - then interface trace- select all, go back- then networking trace -select all. save and then connect to the pc suite it works. this is for samsung j210. i believe it will work for others aswell.
  • Anonymous Aug 22, 2008
    Same problem... And gettign really annoying!!!
  • jac4 Aug 28, 2008
    Yep! Same phone. Same issue. I don't have the USB cable. I'm on Blueteeth, but it seems to make on diff at all. I have got it to work but that was more luck and after messing with it. I'm not sure why this is happning but Sam needs to fix it. My phone is sending. My USB dongle is working and I see that the PC Suit is showing that it is connected with the phone. From there is should work. This is especially annoying as I've just come from a Nokia 6230i the most robust phone ever with A+ Nokia Software >:((
  • lizz_ie Nov 04, 2008
    Exactly the same problem.(Time consuming operation).
    Just found this site and followed instructions then HEY PRESTO.........IT WORKED.
    Thanks to all
  • Anonymous Nov 27, 2008
    PC studio is a piece of ****
  • Anonymous Dec 18, 2008
    :| i have the same problem.... pls somebody help !!!! cuz i dont know what to do :(
  • Anonymous Mar 13, 2009
    Thanks
  • Anonymous May 11, 2010
    The fix doesn't work for me. Once I type *#52828378# into phone thiThe fix doesn't work for me. Once I type *#52828378# into phone this comes up
    1 Trace setting
    2 OTA type setting
    3 Serial test
    4 TFS reset
    kindly help -- i'm still stuck with the same issue in pc studio suite. I've the latest SGH-J210 handsets comes up
    1 Trace setting
    2 OTA type setting
    3 Serial test
    4 TFS reset
  • kinikya May 11, 2010
    I also have an SGH-G600. Are we supposed to do that same code every time we have that problem?
    It keeps happening. The My File folder doesn't appear on my PC when I try to synchronize with PC Studio, it freezes. I have Win XP
Ok.... found this on another forum, tried it and it works! Fixed my problem, which was exactly the same as yours. Unplug usb cable from phone Type *#52828378# into phone and this comes up 1 Trace setting 2 OTA type setting 3 Serial test 4 TFS reset select 3 serial test and this comes up 1 PPP UP 2 Serial download 3 Run TCK Select 2 Serial download The phone will reboot and once its rebooted connect usb cable and pc studio will work.
Posted on Oct 09, 2007
I was also facing the same "another program ..." error. I swiched off my mobile and switched it on again before connecting. And it worked !!!
Try out and see if it works for you also
Posted on Aug 21, 2008
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
Posted on Aug 20, 2008
I Just Dial *#52828378# Then it Comes
  1. Trace Setting
  2. OTA type setting
  3. Serial test
  4. TFS reset
The i click on TFS reset and then on JAVA full reset now my games aren't full screen
How can i make my games full screen? plz help me out
Posted on Jul 20, 2008
I also have Samsung SGH J210 and even I had the same problem.I tried the following procedure and it worked.First install the drivers and install the latest version of Samsung PC Studio.Switch off the Phone and remove the Micro SD card from the Micro SD slot.Switch on the Phone and in the PC connection settings in the Phone select Samsung PC Studio.Now connect the phone to PC and it works.Now disconnect the Phone from PC,once again put back the memory card and it works.
Posted on Sep 15, 2008
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
Posted on Apr 08, 2008
I tired this solution on my G600 and it works. Thanks.
Posted on Oct 31, 2007
  • 4 Answers
Use windows XP, not windows vista or windows 2003
Posted on Oct 20, 2008
Phone restarts by itself from time to time even when its fully chared
Posted on Sep 27, 2008
  • Anonymous Sep 27, 2008
    hello does any one have any master codes for the d900
    my d900 shows that it is connected to the pc studio 3 when software updates for the phone are being downloading but when the phone update software tries to install the updates the phone update software says phone is not connected can anyone help me please
Ye turning the phone off before worked, ha.
Posted on Sep 17, 2008
You may try switching off your mobile for a short wile before switching on and connecting to PCStudio. I have the same problem with my J210 even today, and this works for me for every single time.
I have recently purchased Samsung-J210, and the common problem of an error message saying "Another PC Studio program is performing a time-consuming operation. Retry after this operation is finished" came.
I did the following and it was up perfectly: -
Setting - Phone Setting - PC Connection - Ask on connection
Posted on Aug 11, 2008
I Just Dial *#52828378# The it Comes
  1. Trace Setting
  2. OTA type setting
  3. Serial test
  4. TFS reset
Absolute genius thanks so much
Posted on Nov 04, 2007
Yep, problem solved :-)
  • Anonymous Nov 04, 2007
    Worked perfect for the G600!
Job Done, that has been annoying me for so long, thanks alot mate. kiss kiss
Posted on Nov 01, 2007
Absolutely perfect, 2 minute job, thank you very much
Posted on Oct 23, 2007
Well done that man !
Saved me a lot of aggro x  x x
Posted on Oct 18, 2007
THANK YOU MAN!
Posted on Oct 15, 2007
Worked perfect LilyMyLovely thanks
Posted on Oct 14, 2007
I had the same problem, if you restart your pc as well as your mobile it will work.
still the problem persits unistall the pc sudio from add remove prog and reinstall
Posted on Oct 27, 2008
SOURCE:
Hello people I've a problem with my samsung sgh g600 I can not connect to the pc it does not connect her help me please
this worked for me ......
and this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
and this comes up
1 PPP UP
2 Serial download
3 Run TCK
THANKS
Jun 29, 2010 | Nokia 6233 Cellular Phone
I cant connect to the pc studio 3 using my sgh g600 samsung
You did not indicate the option you tried using. Try all the connection options: USB, Bluetooth, infra red etc. If it does not, your might be having problem with the configuration of the pc studio.
Oct 30, 2009 | Samsung SGH-G600 Cellular Phone
Cant seem to download photos from my phone to my pc.my phone is a g-600 and i have never downloaded pictures from my phone before i have put the ubs cable in and the disc that comes with the phone but...
Disconnec the phone from the PC. insert the Disc and run and install the Samsung PC Studio on the PC. Now reboot the PC. Connect the phone to PC via the USB cable. And the PC should say SGH G600 connected. The with the help of file manager on the Samsung PC Studio, xfer the pics to whatever folder you want.
Sep 15, 2009 | Samsung SGH-G600 Cellular Phone
The Samsung disc supplied will not load onto Vista
i just want to say thanks for the help in sorting out my samsung problem regarding connecting my g600 phone to samsung pc studio it worked first time
in phone type * #52828378# into phone and this appears
1 trace settings
2 ota type settings
3 serial test
4 tfs reset
you select 3 serial test
then this comes up
1 ppp up
2 serial download
3 run tck
you select
2 serial download
the phone will reboot connect you usb lead and pc studio will work
Feb 18, 2009 | Samsung SGH-G600 Cellular Phone
I can't transfer files using USB connection to a PC... help!
dear,
did u try with the other cable.
if yes, then reinstall the usb driver for the phone and then try with pc suite or if u didnt install the driver, then u have to install it.
regards,
dont forget to rate it.
Feb 15, 2009 | Samsung SGH-G600 Cellular Phone
My samsung G600 wont connect to my pc studio 3 on computer?
If you are using pc studio you must first check that it is set to use it.Try this first:-
1,settings-phones settings-USB settings-pc studio.
2,If not then check that your pc USB's are switched on.
Aug 25, 2008 | Samsung SGH-G600 Cellular Phone
Samsung SGH-G600 connection to pc studio3
Try this, I had a the same problem as you guys + found this on a web forum. Quite a frustrating problem to have, It fixes the phone, but after a while you have to do this over again. I am wishing I never bought this phone, even though the reviews were really great.
this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
this comes up
1 PPP UP
2 Serial download
3 Run TCK
Phone will reboot.
Once rebooted, connect usb cable and pc studio will now work.
Aug 06, 2008 | Samsung SGH-D900 Cellular Phone
Cant get SGH-G600 connected
hi i have the same fone wen u have installed ur pc suite click on it go to file an go to connet click on it make sure ur usb is in the fone an pc an it shud work remember fixya at the end ov ur solution thankyou
Jan 09, 2008 | Samsung SGH-D900 Cellular Phone
SAMSUNG SGH G600
have you tried  pluging into another spare usb slot on pc .also have you done any updates for the pc studio software recently.
http://uk.samsungmobile.com/wcms/products/phones/phonedata/download/UK-SGH-G600.jsp
riz.
Oct 16, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
10,438 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
