Question about Gestetner A045 Wide Format Copier
How to use RW-240 Scantool... I can't figure it out. I am trying to scan blueprints into a file, and haven't done it in over a year, and can't remember how.
A045 RW-240 SCANTOOL Free Swoftwair
Posted on Oct 07, 2009
  • 163 Answers
Make sure both pc and a045 are ready
start plot base (4 applications should start)
now start scan client
Posted on May 07, 2009
SOURCE:
How come my RW-240 Plotbase (Software for the plotter) will not show any files that have been sent to print?
This plotbase is old enough. Try to reinstall everything. Maybe there is a problem with your PC OS. Try to install plotbase on other PC.
Oct 14, 2014 | Ricoh - RW-240 Print Controller - 411737
My pc suddenly can't download any files from internet. Anyone know how to solve this issues?
Try to re boot. Have you done a malware scan, if not reboot in safe mode with networking, try to download MALWAREBYTES AT:http://www.filehippo.com/download_malwarebytes_anti_malware/. Run a FULL SCAN and delete any results. Are you sure you are connected to the outside world? When you open "Network and Sharing Center" and verify your connection,if you haven't already.
Nov 04, 2012 | Toshiba Notebook 883974582570
Free Download software for the unitech pt630d
just try this link
http://www.unitechnical.info/Products/PT063D4index.htm
click download software pc driver.
Feb 05, 2011 | Unitech PT630D Portable Terminal
Any RW-240 drivers available for Windows 7?
I know it is a bit late but my company had the same problem just a few weeks ago and I figured out a work around that might help.
First of all, we have a computer dedicated to our Savin 2400 that still runs XP. I found this
http://www.howtogeek.com/howto/33088/print-files-from-anywhere-via-any-device-with-dropbox/
which allows you to set up a dropbox and has a .vbs script that is set to auto print.
From there it was easy, just go out and download a pdf image writer like this one
http://www.pdfill.com/freewriter.html
or any other document writer and set the default folder it saves to in the dropbox print queue. This will let you hit print, select your document writer (which you can rename to "ricoh") and print away!
Jun 02, 2010 | Gestetner A045 Wide Format Copier
By mistakely my scantool or rw 240 has un installed, How i can re install it
scantools is installed with plotbase.
are u able to print?
if not , u need to install the full software .
(hope u have the serial no.-- on the interface card in the pc)
Oct 07, 2009 | Gestetner A045 Wide Format Copier
I can't figure out how to scan multiple pages to one file
Hi There !!
Thank you for choosing fixya.com
It is possible to scan different batches scanned from the ADF into one PDF file. When loading more pages in the ADF after the first realm is finished, it asks if you want to continue scanning to the same file. After that, it will continue scanning to the same file. However, this feature can be selected in the Adobe Acrobat application itself. From HP software, if we load the paper after one realm of paper in the ADF is finished, it will scan the second realm to a different file. If you want to continue scanning to the same file, you need to have either Acrobat Exchange or Adobe Acrobat installed on the computer. Adobe Reader will not provide this feature. After installing either Adobe Acrobat or Acrobat Exchange, perform the following steps to scan pages to a single file:
  1. Make sure your scanner is turned on.
  2. Start Acrobat Exchange or Adobe Acrobat.
  3. Put the document into the scanner (usually face down on the scan bed).
  4. In Adobe Acrobat, click File , then Import , and Scan .
  5. Select the device and whether you are scanning a single- or double-sided document.
  6. The scanning software opens and the scanner completes a preview scan.
  7. When the preview scan comes up, make any adjustments you would like, including selecting the area you want to appear in the final scan.
  8. Click Scan . This will get the final scan into the computer.
  9. Your scanning software should take you back to Adobe Acrobat.
  10. In Adobe Acrobat, you should see a small window asking you if you want to scan another page. If the document you are scanning has more than one page, click the Next Page button. If this is the only page, click Done .
    NOTE: Scanning multiple pages causes each page to append to the previously scanned page. If you have multiple pages, but want them to be in different files, click Done after each page to create separate files.
  11. When you have scanned the last page, click Done on the window described in step 10.
  12. Your scanned pages will open in Adobe Acrobat. Scroll through to make sure that everything is there.
  13. Click File , and then Save As to name your file and save it.
Still unable to figure out, How to do this? Here are some tutorial on HP website that might help.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1161389&prodTypeId=18972&supportTaskId=23095
Hope this would help.
Regard's
Anurag Shukla
Sep 04, 2009 | HP LaserJet 3055 All-In-One Printer
In scanplot base software in A045 machine gives error when you run error is below You donot have memory access. Notice you have the instructions in user manual(RW-240 scanplot setting)? but i have checked...
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Mar 12, 2009 | Gestetner A045 Wide Format Copier
2,042 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
