Question about Samsung CLX 3160fn All-In-One Printer
Stop the Samsung CLX 316FN from answering the house chat line
For some reason Samsung CLX 316FN is answering the house phone line. I have 2 lines coming in, one fax line, one house chat line. The CLX 316FN answers both lines. How do I cancel it from answering the house chat line? I want it to answer the other line, and it is. Thanks
  • 161 Answers
Make sure that the unit is hooked to the fax line only. Many people often merge both lines when connecting answering machines and more than one wireless phone. Also make sure that the unit is the FIRST equipment connected from the wall outlet. Finally, enter the program mode and make sure the fax setting is turned to FAX or TEL. The first setting makes the unit answer after the amount of rings programmed, while the other setting is for manual reception only. One final notice: if you are using the phone line for talking and someone hits START for a copy, the unit will assume a fax and iterrupt the communication. To avoid this, press NO. COPIES first before making copies. Even if it is for one copy only.
Posted on Oct 04, 2007
SOURCE:
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
I have a samsung CLX 3160 Multifunction Fax. I have had the fax for a while and typically have no problem in receiving a fax. I need to know which one of the ports to put my phone line in that goes to the...
Hi again,
For some reason I could no longer view your responses.
Nonetheless, I posted in the Live Session a method of verifying the fax sending capability even in the absence of a receiving fax machine.
Cheers.
Dec 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Having trouble connecting samsung clx-3175fn multi function printer to home phone and dsl to enable me to send and receive faxes
Make sure you attach a dsl filter to the Samsung. Should look like this: Samsung/filter/phone line. Should be installed like this: filter to Samsung bottom phone jack, phone line to filter. Attach the home phone to the upper extension jack from the Samsung.
Nov 27, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Fax one phone/fax line but always answered by fax
You can change the number of rings before the fax machine can pick up. Three is usually a good number. You would have to pickup the phone on the first two rings.
They make devices that do that but everytime I have used them I would end up getting the fax tone when I'm trying to make a voice. The boxes are great at dealing with incomming phone calls from pstn or land line based calls, but if you are getting cell phone calls or voice calls comming in from digital, DSL, or VOIP lines, it has a hard time sensing voice from fax when people are using phones like that. There designed for analog phone line installation but if you're on a DSL they won't work.
Sep 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax interrupts phone call
1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
Be blessed.
Sep 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
222 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
