Question about Dual Pro2- WM795V Channel VHF Wireless Microphone Microphone
Pro2-wm795v I need a replacement antenna - where can I find one?! I've looked but not sure if what I'm seeing will fit. It has a right angle BNC adapter on the antenna.
What type of ariel do i need for uniden ubc92xlt scanner
Are you looking to replace the antenna on the unit or hook it up to a larger separate antenna?
The antenna connector should be a standard BNC, there are a range of antennas to choose from either way.
Dec 31, 2016 | Uniden BC92XLT Handheld Scanner
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
Standard Horizon HX 471. Antenna is to long to fit in Dive Canister. Can I removed antenna or replace with more flexable antenna?
Yes, as long as it is the right length and impedance, you can use a piece of wire! ... If you can get a smaller "antenna" and it fits, it will work fine. You could try disassembling the "Old" antenna, inside, you will find that a it can then be bent or such, use heat shrink to seal it, when modified.
Feb 26, 2010 | Standard Horizon HX471S (824 Channels)...
Where can i buy a new microphones
Try http://www.google.com/products?oe=UTF-8&sourceid=navclient&gfns=1&q=n Start there and look for what you want. It shows you models, price comparison and when you click on a supplier such as Musicians Friend you can find all the details such as the phone number 1-800-391-8762. That was for a Shure mike.
Jul 16, 2009 | Dual Pro2- WM795V Channel VHF Wireless...
Can't find satellites
The internal antenna BNC connection (the little steel bayonet that the secures the antenna or extender cable) is a common failure on these units. The threaded retaining ring on the outside of the antenna BNC comes loose when installing/removing the antenna connection, and eventually the BNC rotates and the solder joint inside fails. This happened on mine recently, if you are handy fixing small mechanical parts and a good solderer it is pretty  easy to fix. Remove the batteries, remove all six outer case screws (but not the one with the oval metal plate) and gently pull the housing apart. Check the solder connection of the coax wire to the BNC pin & shield. If it's broken and the BNC is loose in the GPS case, tighten the outer BNC retaining ring VERY tight, add a drop of thin super glue (Hot Stuff or Permabond CyA, etc) to keep the ring/BNC/case mated, then repair the coax solder  connection. Replace all the screws and test it outside. If it's an aviation GPS you would of course have this done by an FAA licensed avionics specialist. Wink wink.
Jun 14, 2009 | Garmin GPS III
Pro. 2 WM-795V Wireless Problems
The mic volume is to loud. Turn it down a little.
Jan 22, 2009 | Dual Pro2- WM795V Channel VHF Wireless...
I need to sawder the antanna back on is there a certain way
if the telescopic antenna is broken you cant solder it, but you can buy a replacement antenna,some scanners have an antenna that just screws into the circuit board through a hole in the top of the case,or you can get a telescope antenna that will attach to antenna jacks on the back of the set if it has those, which im sure that model does. Antenna jacks came come in several types , one is called a BNC which just pushes in and turn about half a turn to lock in place,also some scanners have the type of jack like the back of a car radio, with those you just push them in and you can find telescopic antennas with the auto type plug at a 90 degree angle that will work fine.If you need more help let me know
Jan 07, 2009 | Uniden BC350C Base Scanner
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
69 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Unspun01
Level 1 Expert
Lawrence Oravetz
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
