Question about SanDisk Sansa e260 MP3 Player
Error with formatting
I have tried to do a firmware update and every time it almost completes then comes up with a message "ERROR! Application failed to read the version details." So my question is how do i get the version details back on the player. P.S. when i try to format using Disk Managment it stops just before the and says "the format did not complete successfully" Please if u can help me i will be your best friend
  • 626 Answers
Its not a firmware update you are running, it is a recovery tool. The "application failed to read version details" error is because it is not meant for your device. You have a Rhapsody version and the firmware is different. You will need to call SanDisk for them to email support documents. SanDisk Technical Support 1-866-726-3475 If you are truly trying to format the device, change the mode on the device Settings>Mode or USB Mode, then try formatting again. Best of Luck.
Posted on Oct 07, 2007
SOURCE:
Error message?!?!
If this is a firmware update, use MyTomTom application and delete the firmware and try again.
Aug 03, 2012 | Tomtom XL 330 Car GPS Receiver
Won't turn on
some virus affection will cause the application not to work reinstall the application.or it may be due to any circuit failure
Jul 05, 2008 | Creative Labs Zen Digital Media Player
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
Blackberry 8520 curve was reset app 523 error what i do
Connect to the Desktop Manager. If your device still having problems. Wipe it with BBSAK. Then insatll software from Loader application.
May 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Error 523
Take it to a dealer if you are not 100% OK doing the following:
The error is caused by an installed application failing and damaging the BlackBerry Operating system in the process. The fix is to simply erase and reinstall the operating system to your phone. This sounds difficult but isn't too hard in practice. It's something you can do yourself on your home PC using BlackBerry Desktop Manager. If you don't feel confident in doing this yourself then you can take it to a BlackBerry repair centre and they'll carry the repair out for you, but you might have to wait a couple of weeks for them to do it and if you're out of warranty you'll probably have to pay for it.
In most cases, the 12 steps listed below should get your handset working again & the process is exactly the same if you want to upgrade your firmware to a newer version. Before you start though I'd recommend that you check the following:
The battery in your BlackBerry handset is fully charged.
*Internet Explorer is needed to download latest version of BlackBerry Firmware. BlackBerry Desktop Manager isn't an essential part of the process, but it will make managing your device a lot easier.
Once you've downloaded and installed the latest versions, it's time to start updating your phone. You'll need to be patient though, as this isn't the fastest process in the world and it will take some time to erase everything and then reinstall the software. When I ran through it for this post it took around 45 minutes on a BlackBerry Curve 8310 upgrading to 4.5.0.163 on a PC running Windows XP SP3.
To be on the safe side, I'd close any other applications on your computer and go make yourself a coffee while you wait for the update to finish.
It's extremely important that once you start this process you don't disconnect your BlackBerry from your computer or switch your computer off until the update has completed and you're told it is safe to do so by the update application.
6. If you're asked for a password, type in your BlackBerry password and click Next.
7. The Device Application Selection screen appears. Select the applications to be loaded onto your BlackBerry smartphone.
Update BlackBerry Firmware - Select Applications to Install
8.If the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry smartphone. Click Next.
9.Click Next. The 'Completing the Application Wizard' screen will appear and display all the software that will be loaded to your BlackBerry smartphone.
10.Click the Advanced button and make sure that Erase all application data and Erase all currently installed applications are both selected. Note: If the Application Loader is not able to access all of the BlackBerry smartphone data, then both Erase all application data and Erase all currently installed applications will be grayed out.
Update BlackBerry Firmware - Check 'Erase all' boxes
11.Click Next, You'll be asked if you want to be notified of future updates, enter your email address and then click Next again.
12.Click Finish. The BlackBerry firmware will now be updated on your BlackBerry. You'll need to be patient though as this will take around 45 minutes to complete - maybe longer.
Update BlackBerry Firmware - Software will take around 45 minutes to udpate
13.That's it - All done. Once you see the update successful screen it is safe to disconnect your phone from your computer.
Update BlackBerry Firmware - Update Complete
If you get any error messages at any point, you may need to start the process again. If you try 3 times and it still won't work, you'll need to take your handset to your nearest repair centre or contact BlackBerry for help.
Jan 12, 2011 | RIM BlackBerry Curve 8520 Smartphone
My magellan 4040 when after trying ton update firmware keeps giving me a unable to lad application with a venus version is error
magellan 4040 when after trying to update firmware keeps giving me a unable to load application with a venus version is error! message
Dec 21, 2008 | GPS
Flash errror
I was having the same problem as the rest after hooking my RCA S2001 MP3 player up to my new computer that is running Windows Vista Home. I did the following to fix my MP3 player on my old computer which is XP Home.
I fixed my player by loading the latest firmware version (1.5 at this time and can be found at http://www.rcaaudiovideo.com/product.aspx?product=124&post=6 ). After you load this application to your computer you access the update device application from the start menu/programs/RCA digital Audio Player/Jet/Update device. One thing that I had to do that had not been mentioned yet in this forum was selecting "Format data area"
Doing this wipes your device completely clean but it allows for you to keep using the device. The update device program will give you additional information after the update and format.
This should fix your device if not contact RCA through the same website above to ask additional questions.
Jan 06, 2008 | RCA JET S2002 MP3 Player
Java Applications Not Working On My Cingular Se w810i
Reinstall the Firmware or updating to the latest software from S.e 's site.
that must be then some hardcore java errors?
Nov 04, 2007 | Sony Ericsson W850i Cellular Phone
Error Message
This just sounds to me like you have a slight error. You may need to update your firmware/drivers or formatting.
One of those solutions should fix your problem.
To update your firmware you will need to visit your mp3 players manufacture, I have found your firmware all you will need to do is visit this link and download the firmware/drivers -
http://www.sandisk.com/driverdownload/index.asp
Once your on the website choose your mp3 player ect.. then click download.
If that doesn't do the trick my final solution is to format your mp3 player then update the firmware/drivers.
To format a basic way follow these steps. First click on "Start" - then go to "My Computer" - then look for your mp3 player if the name hasn't been customized it will come under the name of "Removable Disk" - once you've found it right-click on it then click on "Format".
Once you've formatted then do the first solution surgested. which was install the firmware/drivers. Once you've done that upload music back on to your mp3 player then see if the problems be fixed.
Good luck. Hope my solutions were helpful.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
MTP DB Mismatch Format? Please Delete More Than 4.0 MB
most reliable way to clear the device is to use the firmware update utility.
version 1.005a can be downloaded here
Aug 21, 2007 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
