Question about Sony Cyber-shot DSC-W100 Digital Camera
SONY DSC-W100 1)I need to reset all default setting on my camera.Is there a reset button on this camera? 2)I have trouble taking pictures at a night baseball game.What is the best setting for this camera?Thats why I messed up all the setting cause I played with all the settings and I could never get a good picture all night.Thanks
  • Anonymous Apr 10, 2009
    The grey button doesnt work. I mean I tried to push it in, it doesnt work
    Problem Solver:
  • 11 Answers
It can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear  as blurred due to slow shutter speed.
Posted on Oct 23, 2007
There's a little grey button next to the memory card slot. That's the reset button.
Posted on Sep 20, 2008
    Problem Solver:
  • 7 Answers
Look in the menu for the reset function.
Posted on Dec 02, 2007
Camera want flash sony dsc-h3
If it flashes when you take any photo then you have the flash set to manual override for each shot or you're just shooting in areas too dark for any photos without the flash. Check your flash settings or try a factory default reset from the camera's menu options.
Oct 14, 2014 | Sony Cybershot DSC-H3 Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
How to disable the vibrate function in my sony cyber shot DSC-T70 and where i can find it
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
Thanks for contacting FixYa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Cyber-shot DSC-W55 Digital Camera: sonyW55 lens only comes out half way ,can not take...
1.Please reset the Camera to its factory defaults and check if it helps.
2.To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
If you're not able to access the menu option in the Camers, try this:
Power Reset the Camera and check if it helps
To Power Reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 30 seconds.Then, reinsert the Battery Pack after 1 minute and check if that helps.
Please Power Reset the Camera and I am certain that it should resolve the issue. If the issue still persists after Power Resetting the Camera, then it requires service.
http://eservice.sony.com
May 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When I snap a picture the screen turns purple and that is the picture I get
Please reset the Camera to the default settings to resolve this issue.
To reset the Camera, please click the Menu button, then select Setup1 and select Initialize and click OK.
You can refer to the User Guide of the Camera from the below link.
http://www.docs.sony.com/release/DSCW30-W40-W50-W70.pdf
Please refer to the page # 53.
Regards,
Prashanth
May 10, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Pictures are turned small
Please initialize (reset) camera by going into camera menu, this will set camera on its default settings.
Initialize option procedure is written in user manual.
Mar 19, 2009 | Sony Cyber-shot DSC-T50 Digital Camera
Camera reset for w90 and w200 sony
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Feb 23, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Pre-shooting with sony dsc H2
There's a chance that the settings might have been changed.....Just try after resetting the camera to default factory settings.
Mar 05, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony DSC-P72 won't snap a picture
Have you done a "hard" reset?
Under the jack cover (below the zoom rocker on the back of the camera) there is a small "reset" button. You'll need to press it with a sharp object, and hold it down for a few seconds. If it was a setting problem, this should resolve it.
Nov 11, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
378 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
