Question about GoVideo DVD-VCR Combo
DVD sound problem
I have a proluxe CE 818 dvd player which will not play the sound for the main characters. All background sound is there. Some cartoon dvd's play ok. I'm a bit puzzled.... Have gone thru the menu but cannot change anything that will make a difference. Many thanks for your help.
  • Anonymous Nov 25, 2007
    Dear Sir/Madam,
    I have the exactly same problem as example. I have a proluxe 818 dvd player that can not play the sound for the main characters. All back sound is there. Some dvd's and cd'scan play. I have gone through menu but can not change anything.
    How can I do?
    Kind regards,
    Shohei
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
Posted on Dec 01, 2007
    New Friend:
I had same problem, I did as drewbar suggested above. My settings are: bass - off; front speakers - large; Center speakers - none; surrour speakers - none; sub-woofer - none; test tones - off; center speaker delay - no delay; surround speaker delay - no delay; digital output - off. Got sound!
LOL
Posted on Apr 05, 2010
HOW do you deselect the LARGE or SMALL? Also there is no OFF. Anyone?
Posted on Feb 23, 2008
SOURCE:
My panasonic dvd player is not playing the sound of the main character's voices on two diff. dvd's. Background noise and music is fine. The disks work on another dvd player, and other disks have no problem...
You are listening to a Dolby Digital source and you either don't have a center speaker hooked up or, it's not enabled. If you only have 2 speakers connected to a surround receiver, switch your receiver from surround to surround off. If this doesn't work, or you need more help, specify your system and how it's all hooked up.
May 03, 2009 | Televison & Video
Sound on DVDs
It sounds like she has the player set to output 5.1 surround sound, but only has left and right channel speakers hooked up. Either change the dvd player to only send two channels or hook up a center channel speaker.
Jan 01, 2009 | Computers & Internet
Improper sound when playing DVD
you may need the latest codec pack, here is the web address:
http://www.xpcodecpack.com/download
hope this solves your problem
Nov 15, 2008 | Panasonic Toughbook 48 Notebook
My DVD player will only play background sound not voices
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
Nov 09, 2008 | Televison & Video
I have a Pioneer DV 585A DVD player that happily plays DVDs and the background sounds seems to be fine, but on some of the DVDs you can hear the voices of the characters speaking and then on another you...
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 13, 2008 | Televison & Video
Sound
It is due to setting of Audio options in 5.1 and having only 2 speakers for stereo. For enabling conversion select "stereo" option from Memu under sub category "Audio"
Jan 05, 2008 | Philips DVD580MT DVD Player
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Proluxe ce818
I have this DVD player, and it has surround sound connectors, and seperately L/R connectors.
Whilst the L/R should mix-down the surround sounds, it doesn't appear to and only actually play the surround sound left and right.
My solution was to plug one of the RCA leads into the "Center" of the surround output, (can leave the other in the L or R slot)
you'll then get voice, out one speaker and ambient sounds out of the other.. It sucks, but that's why this things a freebie.. it's not well designed :P
Nov 26, 2007 | GoVideo DVD-VCR Combo
GoVideo DVD-VCR Combo Logo
217 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
