Question about Cornerstone FIC AD11 Socket A ATX Motherboard W/ AUDIO (BRAND )
Turn computer on but get no picture
Tried 2 plug in anew video card but still no picture. can hear the hard drive loading but monitor wouldnt turn on
  • 23 Answers
Please, go to the bios without inserting the video card and in the pci/plug device there is an option : initial display u can choose as AGP for the first display. then u can save and exit. after restarting the system u can turn off and insert the agp card and connect to the monitor. this will solve ur problem
Posted on Oct 06, 2007
6ya staff
SOURCE:
When i power on my pc moniter not started hard disk light not blinking..
Are you powering on your computer and your monitor...
If your computer appears to boot, but nothing on your monitor...
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
If your computer won't boot...
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Aug 05, 2014 | Computers & Internet
When turned on, it shows the picture for a second
stays on 5 mins screen turns black i push screen power on and stays on 2, 3 mins and turns off again
Dec 31, 2009 | ViewSonic VX715 17" LCD Monitor
I installed a new hard drive,when I power up the tower, it beeps twice and the monitor says no signal. I reinstalled the old hard drive and the same thing happens.
Greetings,
If the monitor says no signal then you generally have a video issue not a hard drive issue. Make sure that the cable to the monitor is plugged in securely on both the monitor and the computer. If you have a video card make sure that it is seated correctly in the slot. You could also try a different VGA cable. Let me know if you have any more questions.
Good Luck,
-WN
Dec 17, 2009 | Dell Dimension 2350 PC Desktop
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Graphics Cards causes computer to not display
Hi there.
I'm working on the assumption that the graphics card is a PCI Express card.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | Vantec iON 2 VAN-460N (VAN460N) 460-Watt...
Computer OS won't load
yes, I think your memory is the problem, it's crash
it is hardware problem, not system
May 31, 2009 | Dell Dimension 9100 PC Desktop
Tried Installing new Hard Drive, Now no picture
see the hardrive cables and also check that jumpers in hard drive just connect one hard drive at a time first ok set jumpers to master settings and then try if the problem persists
Try changing RAM it is the main culprit if ur computer is unable to boot and ur vga is ok as u told me
pls do rate me if it helps or fixed ur prob
Feb 24, 2009 | E-Machines T4155 PC Desktop
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Open Questions:
See all Cornerstone FIC AD11 Socket A ATX Motherboard W/ Questions
Cornerstone FIC AD11 Socket A ATX Motherboard W/ AUDIO (BRAND ) Logo
60 people viewed this question
Top Cornerstone Computers & Internet Experts
rrackman
bntew
Level 1 Expert
STEVE
Are you a Cornerstone Computer and Internet Expert? Answer questions, earn points and help others
