Question about RCA H116 MP3 Player
I having trouble hearing the music
When I try to listin to my mp3 I can't hear my music unless I move around the earphone connection
  • Anonymous Nov 04, 2007
    yeah same problem.....i cant hear out of my left ear phone and when i move around the ear connectors...what's supposed to be in the left ear is very soft and i can only hear whats supposed to be in the right for when the song is split.....
  • chaffin74 Jun 30, 2008
    Same problem. Just started happening recently.
That doesn't work. I've tried 3 different headphones/earplugs and the problem persists.
Posted on Jun 29, 2008
    Problem Solver:
  • 8 Answers
Need better earplugs not headphones,Walmart has a nice selection also Walgreen Drugs.Try gold tips
Posted on Mar 09, 2008
SOURCE:
Have my earphones on but can not hear music
You could try using your earphones with another device to see if they are working properly. For example, I think my earphones have a broken wire in them because when the earphone plug revolves up or down in the jack the sound cuts out. When I turn the plug around a little, the sound comes back. (I am sure you had the volume turned up :)
Jul 09, 2014 | SanDisk Sansa Clip MP3 Player
How to fix coby cv320 headphones
If you hear sounds from only one earphone then most likely there is a broken wire to the earphone that is not producing a sound.
It is difficult to determine exactly where the wire is broken and repair. I suggest you get a new earphone.
Jul 12, 2012 | Audio Players & Recorders
Can we hear to music without an earphone connected??
You need earphones to listen to music and movies.
Most
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 06, 2011 | Transcend T.sonic 850 Digital Media Player
I hear music threw headphones but not singing also if my wire moves i hear nothing
You may have a short in the earphones. Try a different pair. If that doesn't work then you may need the heaphone jack replaced on your mp3 player. Hope this helps.
Aug 06, 2009 | SanDisk Sansa e250 MP3 Player
Cant hear my music
plz check the ear phones is it connected correctly...or plz change the earphones and try it!!!!
Jul 24, 2009 | Audio Players & Recorders
The radio component will not work. All I hear is static on any station.
make sure you are on fm not am, and make sure you are in a place with good reception. maybe try new earphones or while you have the radio on try moving the earphones and the player around.
May 18, 2009 | Creative Labs ZEN V Plus MP3 Player
IPod Not Working
Does your iPod come on? If not, your battery could be bad.
If you can see the music playing, but cannot hear anything, you could have a bad earphone jack or a bad circuit board.
You can tell if it is the battery the iPod will not come on at all unless it is attached to the computer or to a power outlet.
If you can move the earphone jack around while playing music and hear something, then it is the headphone jack. If you move the jack around and hear nothing, then I would suspect the circuit board.
If you have a device that can play your music out of the USB port on the iPod, you can make sure that it is the circuit board that way. When the circuit board is bad, music will not play out of the headphone jack or the USB port.
Hope that helps.
Dec 09, 2008 | Apple iPod MA446LL/A MP3 Player
Songs and radio skips like a scratched cd
Your mp3 player works like a hard disk, make sure that it was not moving when you are listening to your music. If the problem is the same try to use a new headset/earphone on it. Loose connections on your headset/earphone makes you think that your mp3 player skips.
A Simple Thank you is Good enough
Jan 16, 2008 | SanDisk Sansa e200 MP3 Player
Can't hear music from sansa
Hi. If you have to adjust your earphone (even if you used other earphones) just to get a normal stereo sound, then the problem is with the player's earphone jacks. If that's the case (and assuming the radio feature of the player also manifests the same problem), then you may need to call the tech support guys at SanDisk for advanced troubleshooting, or possibly replacing that player. I found their tech support contact number at their website upon consulting prior issues I had with my player. Here it is: 1-866-726-3475.
May 09, 2007 | SanDisk Sansa e260 MP3 Player
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
RCA H116 MP3 Player Logo
107 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
