-   I need a new danby front load door handle-   Guest
Feb 19, 2009
-   i emailed danby customer service and they gave me the names of their "distributors". of course i checked...and they don't even carry the danby line. any one know how to get ahold of this replacement door handle???
-   lldd
Feb 11, 2009
-   the issue with danby.com is that they appear to no longer sell this washing machine. let alone the parts.
-   Guest
I just fixed this problem - it is very easy and Danby was very helpful.
FIRST OFF - Why this happens: when the washer finishes a cycle, you must wait and additional 2 MINUTES prior to the washer unlocking. That is probably why people break the washer.
Now for the solution - Danby sells the part for under $5.00, part number 533. They will send you a pdf file with an illustration of all the washer parts so if something else broke, you could replace it.
go to Danby.com or call 419-425-8627
Sometimes there is a long wait which is no fun. Ask the receptionist to put you thru to the manager and the manager will take your number and have a parts person call you.
The door to my Danby DWM5500 has a broken door handle. Where can I get a new door and instructions...
(More)
The door to my Danby DWM5500 has a broken door handle. Where can I get a new door and instructions on how to install it?
I've replaced the speed control board because it was bad i replaced the motor and it still won't do...
(More)
I've replaced the speed control board because it was bad i replaced the motor and it still won't do anything any help would be great oh by the why its make that hummig sound like everyone talks about !!
The plastic next to the hinge on the door of our Danby DWM5500 front load washer has broken away....
(More)
The plastic next to the hinge on the door of our Danby DWM5500 front load washer has broken away. Can we purchase a replacement door?
I just bought the washer with a broken door. I ordered and replaced the damaged pieces but when...
(More)
I just bought the washer with a broken door. I ordered and replaced the damaged pieces but when setting the washer to one of the Letters to start running the washer fills but the drum does not turn. It hums and that's about it. I opened it and confirmed the belt looks brand knew but the motor does not turn. I don't see any damage anywhere. The old owners said the washer worked great until the latch broke. Any ideas?
