Electrical Problem with my fatboy
If you have the electric speedo, then it's one problem. There is a relay that all three of these go through in order to work. I'll bet you popped the relay. I don't know exactly where the relay is, but your local dealer can give you the location. If you have the manual speedo, the it's two probs. First, the cable to the speedo gear on the front hub has most likely pulled out a bit, and second, the same relay as before, only the speedo isn't routed through it.
