Question about Hitachi 60SBX78B 60" Rear Projection Television
Hi there... I think the power capasitor is fried... is this a hard fix?
  • kimandlccarr Oct 04, 2007
    There is no power what so ever.
    thanks
    Genius:
  • 1,694 Answers
If the symptom is no sound,no pix--blinking LED, then C702 102K/2KV capacitor shorted and E994 pico fuse open might be problem. If so, consider replacing cap w/ 3KV for improved reliability.
Posted on Oct 04, 2007
  • Vista Electronics Oct 04, 2007
    Check all fuse devices.--With set plugged in,
    observe which chassis LED's are lit.--Is the red
    protect LED lit? Then proceed as in solution #1
    and please let me know.
6ya staff
SOURCE:
Mains short circuit fried drive
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Mar 08, 2013 | Computers & Internet
Pioneer model VSX-3300, I had
here you can see faulty capasitors
Hard to say what may be the problem.
Jun 07, 2008 | Pioneer Audio Players & Recorders
I have a memory frame, modle mf-810. I received it 3-4 years ago, I think. It's worked wonderfully until about 2 months ago when we had a power surge. Is this a power cord problem? or is the frame...
a power surge may have fried it if you don't have a breaker switch on the plug that you plug your power supply into. The only way to really determine is to connect your photo frame into a second power supply if you have one to see if it works. I found out the hard way to always have a circuit breaker for my computer units after a power out fried my computer hard drive.
Dec 27, 2009 | Computers & Internet
Lp820 infocus will not turn on
Some capasitors should be changed in the powersupply and several diodes too, may be. There are temperature mode in the power supply is very hard and those capasitors broke from that. Therefore running of projector is not stable. However if dont change capasitors at time then one diode may be broken and the projector will not start afterthat alwase.
Its not so big work for repaire.
I hope may english is understandable for you.
Best regards. [email protected]
Jun 15, 2009 | InFocus LP 820 Multimedia Projector
My controller connection to my PS3 constantly dies after about 45 minutes whether its plugged into the USB port or not. How do I fix this?
hey i had my ps3 for about 8 months or so i got the message i did everything unplugged it didnt work held power button 10 seconds restarted it nothin- mine makes a weird noise and the orange light saying its loading wont turn off if it does that it pretty much means A. your hard drive is fried B. your hard drive isnt responding with system C. you turned off your ps3 while loading something and it fried it i think is what happened to me
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
Upon booting hard drives not recognized
You mite try to re set the board and I would start with just one HD with the OS shut down pull power plug push the power on switch to let out res power then locate the the bat on the board and remove it you will see a pin select set near the bat pull the connector and change the posision to the other pin (touch the two not together at first) then replace it the way you found it wait a few moments then try to boot again
Oct 07, 2008 | ASUS P5B-E Motherboard
Computer will power up for three seconds then shut down
Had the same problem on a few motherboards, check your capacitors very closely. If they are rounded or split on top they are bad. You can change the capacitors with new ones to fix your problem but it often ends up costing as much as buying a new board.
Nov 08, 2007 | Intel D101GGC Motherboard
Fried Hard Drive
whoa!  what were you thinking?
do you have a WORKING system you can install it in as a second drive?  Power it OFF first, install as second or slave drive. See if you can see files that way.
Oct 13, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
I think I fried my LACIE 500gb drive
Sadly if you fried the drive with that PSU cord it would be pretty hard for a home repair. If you know its definatly dead, I would just remove the drive from the external unit and try to connect it internally to a computer. If the adaptor is different you could buy a cheapy online somewhere.
Jun 18, 2007 | LaCie (300740) 160 GB Hard Drive
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
