How can I fix this used TV I bought???
I bought a TV off of craig's list and its a Mitsubishi CS-27EX1. I don't know why, but when I tested it out before I bought it, the TV was fine, but now the picture tracking is completely messed up. This picture is not clear at all. I thought it was the DVD player or the cables but I tried a new cable and different DVD player and the picture was the same. Any suggestions?? Thanks!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I bought it, the TV was fine, but now the picture tracking is completely messed up. This picture is not clear at all As you have tried externally with dvd 1 it cleraly indicates that there is a loose contact inside near cable socket due to heavy press as you said that it was ok before. 2 loose contact or print break near tuner. 3 tuner defective. good luck.
Posted on Oct 06, 2007
SOURCE:
Need user manual for cs-27ex1
type into your search engine of choice, user manual for cs-27ex1 you might be pleasantly surprised
Oct 02, 2011 | Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Cs-27ex1 sound but no picture
Write to or e-mail the manufature and tell them what your prolem is nomaly they have techs. that will e-mail you back. On units I have worked on in the pest this is all most always coused by a bad cap. If this is a ongoing problem with this modle the factory tech should be able to tell you whith parts have to be replaced and the exact location. hope this helps.
oldgrizzly
Nov 16, 2008 | Mitsubishi CS-32207 TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Diamond shield
It seems these TV's are going bad right and left. I would look on Craig’s list for a cheap/free 55" Diamond TV. Not sure what you would do with the left over TV. I just picked up a 55" Diamond for free and hope to fix it. If I don’t get it to work, you can have the screen (California).
Aug 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Original remote for Mitsubishi CS-27EX1 tv stopped working and now after several months a replacement universal remote is unable to communicate with the tv, which works fine if the buttons below the screen...
The origional remote is no longer available. However you can get the phillips universal remote at the following link. This is one of the best universal remotes available and easiest to program and will work 3 different items. This company ships for free
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Televison & Video
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Mitsubishi CS-35805 TV
Sorry to be the one to inform you Sheri, but this set is known to have several bad capacitors in the sweep as well as the power supply. Unless you have an ESR type capacitor checker, your going to have to take it in for service, by a pro. Hope yopu did'nt pay to much for it. Good Luck
Jul 24, 2006 | Mitsubishi CS-35805 35" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Ekse
