Solution 1: leave door open when not in use and run enzyme cleaner like affresh, or 2 cups of distilled vinegar weekly until smell is gone.
Solution 2: Most of the front load waahers have a manual door lock release. This is usually accessed by removing the bottom front cover and reaching up to the door latch assembly, to pull onrelease cord/plastic ring. If door locks stuck again, you will need to replace the door lock/latch assembly.
SOURCE: paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
SOURCE: washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
SOURCE: I get an F1 error code at the start of the wash & at rinse cycle.
Your Central Control Unit is most likely the problem. It is the main board in the machine behind the control panel and they have been failing a lot. This is a major problem with the Whirlpool Cabrio and the Kenmore Oasis machines. You will most likely need to call a service technician. People have also called whirlpool and complained and got them to pay for the part. I suggest you try battling with them. The part is faulty.
