Question about Panasonic PT-47WX49 47" Rear Projection Television
PT5499HD Covergence Akai
I bought the TV needing repair. I just replaced the sdks on the tv as one was out. The tv seems ok now accept for the convergence. Here where the problem comes in. I used the mute 1 8 3 to enter the convergence mode. All the colors will adjust satisfactorily with the remote, however it looks like the convergence picture is too large. The convergence cursor for the grids will move off the screen for the outermost grid points on all sides. The picture size just seems large. I have no cable or antenna connected to it at the moment. When I use the normal operational user menu, part of it is hanging off the left side of the screen. I have perfromed manual convergences on other tv's with no problem. On this tv I can align the colors and all adjustments work fine,the picture just seems large. Even when I select the factory settings on the remote during convergence the grid is very similar in size and adjustment. Any suggestions? Thanks
  • 3 more comments
  • trakker_ric Oct 04, 2007
    This is an Akai. Thanks
    I also entered the service menu. mute 182 power. That menu also hangs off the left side of the screen. Also when going into one selection, the items extend off of the top and the bottom of the screen. Thanks
  • trakker_ric Oct 08, 2007
    I found the v amp setting and reduced it. That reduced things enough so that I can now see the mute 182 menu top to bottom. The is no h amp or h size setting just an "h ew" . That has limited effect. I did some convergence and brought the horizontal area in where it all seems to appear on the screen. Then I found the 4:3 and wide seting. I have since reset the convergence to factory defaults and I am starting over with the convergence. The h position seems to have no effect. I was wondering if there was a problem, but I do have full control of the convergence. I have made some progress. What is the "h ew"?
  • hardwoody Feb 10, 2008
    picture is too big for screen. i have gone into service menu(mute 1 8 3 ) and cannot figure out how to adjust. your help would be appreciated
  • chantler965 Jun 26, 2008
    PICTURE TOO HIGH NEEDS TO BE MOVED DOWN VERTICALY. cannot read information placed along top of picture
  • 4 Answers
How do you adjust color and picture size
Posted on Mar 08, 2008
    Genius:
  • 1,153 Answers
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Posted on Oct 04, 2007
  • Lashawn Robinson Oct 08, 2007
    need to look for hor. size and bring down.
SOURCE:
The color on my Akai PT5499HD projection tv is now showing yellow tint .. help!!
Most likely bad glycol in the blue picture tube (a coolant) and not cost effective to repair.
SD TECH
May 12, 2011 | Akai Televison & Video
We have 52 inche akai and it shows double inmage
This problems is known as a convergnce problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergnce board,must be replaced to solved the tv covergence board.To solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole rebuild convergence board to replaced.The Akai/Samsung tv used the same convergence board.
Sep 15, 2010 | Akai PT5492S 54" Rear Projection...
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Nov 11, 2017 | Akai PTH5498 54" Rear Projection...
Akai pt5499hd just shut down
If you are electrically inclined, there is a power deflector board that may need to be replaced. This deals with the high voltage part of the TV, so I am not responsible. The part number we had to but and replace was BP94-01289A or about $130.
Oct 31, 2007 | Televison & Video
SCREEN FOR PT5499HD
Check this out USA AKAI CUSTOMER CARE 1-800-726-4405 Hours of operation (Eastern Time): 8:30 am ~ 9:00 pm (Monday through Friday) 9:00 am ~ 5:00 pm (Saturday) CANADA AKAI CUSTOMER CARE 1-800-293-5408 Hours of operation (Pacific Standard Time): 6:00 am ~ 6:00 pm (Monday through Friday Good Luck
Aug 15, 2007 | Akai PTH5498 54" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
461 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
